Results 1 to 5 of 5
Thread: Inlet manifold temperature versus timing 850i
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    does anybody know what the inlet manifold temperature sensors on each bank can do in the DME's….? (or EML ??)
    I would guess they retard ignition timing with raising air temp …. ????
    Or for what is this input used ?
    i see 2.3k Ohm at 20° C …. to 0.5k Ohm at 70 °C .
    thanks for info !
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    no, they set different trim/baselines for the fuel mixtures.
    '91 850i 6sp (mint) (sold)
    Del Mar, CA
    91 850i, 01 740i, 06 760
    When I monitor the inlet air temp in inpa it seems to be about 10 deg warmer than the outside air temp even on cold startup. Both bans read the same. I have wondered if it would be worth correcting this.
    Mine read 2.5K at 18deg.C
    Sep 2018
    Belgium
    thanks for replys.... i'm still looking for the "dip" we have around 4500 rpm. With the charger ( and A/A intercooler) i can assume air temperature is higher than in oem without . So we thought to do a dyno with "false" sensors outside the manifolds , as we supposed they possibly can retard the ignition .
    If this is not the case , we still have our problem …
    What we don't understand is that at 4700 rpm we have 410 HP , and then further to 6000 rpm , boost still climbs , A/F remains good ( dual gauge) , but no extra HP.
    That's why we thought something is retarding ignition.
    PS we only drive 3 sets of the 4 set rolls on the dyno , so all results are x 0.75
    BMW 850i - crank pully - WOKKE EML - HP.pdfBMW 850i - crank pully - WOKKE EML - NM.pdf
    Nov 2015
    Ger
    E31 850iA 1992
    I think the inlet manifold temperature sensors are used to calculate the LOAD signal. Majority for LOAD is air mass flow, minority air temprature.
    Diconnect the plugs to the IAT and make a testrun. In this case, the DME uses a replacement value.
    Can you look/log the ignition timing? So you can see if timing is retard.
    Can you modify your DME chip? For testing, i would programming a linear WOT timing.
    This is the stock WOT M70 M1.7 timing. (no waranty)
    720 4
    1280 12
    1920 21
    2680 25
    3160 27
    3320 27
    3680 26
    3840 26
    4000 25
    4120 24
    4400 25
    4720 24
    5000 23
    5360 21
    5600 23
    6000 29
  1. M43 Inlet Manifold coated in oil
    By championc in forum 1991 - 1999 (E36)
    Last Post: 08-19-2007, 07:50 PM
  2. Painting Inlet manifold
    By natarajk in forum 1988 - 1996 (E34)
    Last Post: 06-19-2007, 11:20 AM
  3. Removing the inlet manifold
    By ClutchSnappy in forum 1983 - 1991 (E30)
    Last Post: 06-17-2007, 03:14 AM
  4. 328 inlet manifold
    By marzman in forum 1991 - 1999 (E36)
    Last Post: 05-10-2006, 10:13 PM
  5. inlet manifold swap??
    By the chemist in forum 1999 - 2006 (E46)
    Last Post: 04-25-2005, 08:20 PM
