Rubber engine and transmission mounts for a street car and solid aluminum for the track, right? Well, it's not that straightforward anymore.
Stock rubber fluid-filled mounts are designed to be soft and comfortable, limiting the NVH (noise, vibration, and harshness) felt by the driver. The drawback inherent with a conventional design is driveline deflection, making it more difficult to put the power to the wheels, as well as making a money-shift or miss-shift more likely as they age. Solid mounts are exactly the opposite of this - they permit tons of NVH while offering zero deflection, making these a must have for track-driven vehicles looking to capitalize on every ounce of performance available. Enthusiasts looking to find the best of both worlds often look to polyurethane engine mounts - and many are disappointed with other designs on the market. Seeking a mount that offers a positive connection yet doesn't deform, fail, or rattle the fillings out of their mouths is frequently a lost cause.
Shop Turner Poly Engine Mounts Here
Until now.
We engineered these mounts with these very concerns in mind. We know if a soft mount offers a sloppy connection it doesn't work on the track, and a solid mount isn't acceptable as a daily driver (for most!) and set out to engineer a mount that would meet the needs for both. At the core of our enclosed design is a partially-constrained, multi-piece polyurethane bushing with precisely-set preload. This architecture absorbs and disperses resonant engine frequencies as opposed to amplifying them (like some other designs do), which results in a positive-connection, enthusiast-feel mount with the vibration. Understanding that heat is a concern for the passenger side mount's close proximity to the exhaust, we utilize a PEEK thermal insulation plate to greatly reduce heat transfer to the polyurethane, making heat a non-issue for these mounts.
Call or email us today! 800.280.6966 or info@turnermotorsport.com
Turner Motorsport
/ // Parts and Performance for BMWs
16 South Hunt Road
Amesbury, MA 01913
800-280-6966
