Results 1 to 5 of 5
Thread: Left blinker don't work but side and rear do blink repalce the bulb and nothing help
    Dec 2018
    Harlingen tx
    Bmw 323i
    Unhappy Left blinker don't work but side and rear do blink repalce the bulb and nothing help
    Why does my front left blinker on bmw 323i 2000 doesn't blink when side one and rear does I have replace the bulb and check for current but nothing
    MauiM3Mania's Avatar
    MauiM3Mania is online now Observer/Master Skeptic Moderator
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Moved from the BMW General Discussion sub-forum.
    88M3 AW 43k miles Project FS
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Have a good look at the bulb holder and mountings to confirm that the electrical connections are good
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    If you have a test light or voltmeter, make sure the bulb socket is getting power. Also check that the bulb you used actually works (in another socket).
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Chicago, IL
    2001 330i and 2005 330i
    Swap it to the right side and monitor the results. My left front blinker was always crapping out until I swapped the socket to the right. I've even tried replacing the socket with no effect. Swapping worked.
    Johnny Murray
  1. left front turn blinker doesnt work, side and rear do?
    By setho in forum 1992 - 1999 M3 (E36)
    Last Post: 04-11-2012, 08:00 PM
  2. Buying 98 740iL but right and left blinkers don't work
    By kenthesfking in forum 1995 - 2001 (E38)
    Last Post: 10-06-2010, 04:27 AM
  3. Left blinker not working.
    By rhaig in forum 1988 - 1996 (E34)
    Last Post: 01-22-2007, 06:46 PM
  4. My driver side blinkers don't work!
    By schnitzer325 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2006, 04:33 AM
  5. left blinker works fine, but right blinker inop
    By Thewiseguy in forum 1983 - 1991 (E30)
    Last Post: 06-26-2006, 08:16 PM
