Results 1 to 3 of 3
Thread: Can’t communicate via obd anymore
    Sep 2017
    California
    E39b54 e21b18 e39b25
    Hello all I have a situation I can’t figure out haha I want to start with saying I’m not to tech savvy with computers and software but I will try my best to keep up
    My situation is I have a dell latitude d610 windows xp that I purchased on eBay
    About a year ago that was preloaded with a couple of softwares (dis v57, sss progman v32, inpa v4.4.7, inpa v5.0.2, NCS EXPERT, tool 32, winKFP)
    I’ve only been able to successfully use inpa v4.4.7, inpa v.5.0.2, dis v57 and (sss progman like twice) I mostly use inpa v4.4.7 because of my e39m73tu
    The problem is I used to be able to switch from ads to obd and would do this often by changing between com 1 and 5, Changing fifo buffers, changing the interface between ADS and STD:OBD in the ediabas ini file,and running the ADSSetup.exe or OBDSetup.exe
    But now I can only communicate via ADS. I’m stumped. my cable is fine I swaped with someone and it worked for them so I’m guessing something got moved or messed around with on my laptop. There was a tuner on my laptop through teamviewer tuning a vw Tdi a couple months back around the time this happened not to sure if he moved something
    Thanks for reading this whole mess
    South Carolina
    2004 330 vert 2004 X5
    Make sure the cap is screwed onto the 20 pin port or the OBD2 port won't work.
    Sep 2017
    California
    Quote Originally Posted by flyfishvt View Post
    Hello thanks for the reply I have tried that and it does not work still. Also I’ve tried it on my 2002 e46touring and it doesn’t work as well.
  1. communications error OBD
    By robkandi in forum 1999 - 2006 (E46)
    Last Post: 02-05-2010, 07:35 PM
  2. external temperature sensor. cant find the diy anymore!
    By detox8907 in forum 1996 - 2003 (E39)
    Last Post: 08-23-2009, 09:16 AM
  3. My right rear window cant get it up anymore!
    By Cereal in forum 1996 - 2003 (E39)
    Last Post: 04-12-2009, 01:23 PM
