Hi fam,
Well, it happened. After replacing that shaky fan (https://www.bimmerforums.com/forum/s...4#post30150544) with a new fan, flange and clutch, the fan started shaking again and this time trashed my radiator. I have to figure out why it's still shaking (my guess is water pump) and then fix the radiator.
So here's my question: what size radiator fits? The E23 OEM parts I've found are pretty expensive, but shouldn't other M30 radiators fit? Wouldn't something from an E28 or whatever work just fine here? Thanks in advance, as always.
If you looked up on reloem then clicked on part number it will list what other cars used the radiator.
As a general rule, just about nothing interchanges w/ e23's other than e23 parts. I have a good tested spare radiator if you end up needing one.
Steve H.
