Results 1 to 3 of 3
Thread: flex in pedal bracket = broken bracket?
    Dec 2018
    San Francisco, CA
    1985 BMW 528e
    Question flex in pedal bracket = broken bracket?
    So my clutch will not disengage when I press the pedal down. I have replaced the master and slave cylinders, bled it every which way I can, and it feels stiff enough..
    however, when I look at the bracket while pressing the pedal down with my hand, I notice a bit of flex in the pedal bracket, not much, but maybe a couple mm... So I am wondering if its the dreaded cracked pedal bracket. Thing is, I dont see any cracks where people have described it to be.... thoughts?
    Dec 2018
    San Francisco, CA
    1985 BMW 528e
    clutch wont disengage despite changing master/slave cylinder..
    After changing master and slave cylinders, and bleeding and bleeding and bleeding the slave, I think that its where it should be in terms of firmness. still not disengaging the clutch. The pedal bracket seems to have a LITTLE flex in it, but not much... like MAYBE a millimeter or two... Not sure if thats enough to be a problem... or if I should now be looking elsewhere for the problem like the pivot pin, throwout bearing, or shift fork. Any way to rule those out WITHOUT dropping the tranny?
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    Looks like you need to drop.
    Andy
  1. E60,E61 Fs: Headlight with broken brackets for parts
    By ///M297 in forum Exterior Lighting & Body Parts
    Last Post: 03-26-2010, 06:47 PM
  2. Is my fog light bracket broken?
    By manynames3 in forum Lighting sponsored by BAVToys
    Last Post: 01-20-2008, 09:19 PM
  3. car-side bolt for exhaust bracket broken
    By elkniwirep in forum 1991 - 1999 (E36)
    Last Post: 10-19-2006, 11:49 AM
  4. broken bracket off of tranny
    By drivesfast in forum 1983 - 1991 (E30)
    Last Post: 08-28-2005, 09:57 PM
  5. Broken bracket, exhaust rattle
    By badmonkey in forum 1992 - 1999 M3 (E36)
    Last Post: 07-04-2003, 12:16 PM
