04 330Xi all over the road in the snow, rear end wants to let loose and spin me out. Pulled a code under ABS #62 Swerve detection. Any idea's? Can't find any info on this code.
Could a rear wheel speed sensor cause this issue?
Since the fault is in traction control i believe, there are yaw and pitch sensors that monitor the additude of the car. I would read the fault with Ista or autologic and see what it says for fault discription
https://forum.e46fanatics.com/showthread.php?t=303141
I don't see the #62 code you have...how did you get it?
Is your alignment off? If the steering wheel is at too much of an angle (not straight) in comparison to the yaw sensor, it will behave erratically.
