Results 1 to 25 of 36
Thread: M50b25 stock intake manifold and throttle
    Nov 2009
    italy
    325i e36
    Hello do you know how much hp can handle
    Stock intake manifold and throttle valve?
    I get 530 hp changed camshaft exhaust ar etc but seems there is something lock power around 530 hp and i thought was intake or throttle
    Thank you
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by leomarcus View Post
    Thank you
    I made 1000whp on a m50 intake and stock throttle body.
    Turbo sizing and tune.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Nov 2009
    italy
    325i e36
    Gt35 t4 flanged exhaust ar .82
    Compressor Wheel61.3 /82 mmTurbine Wheel62 /67.8 mm
    Mar 2012
    Renton, Wa
    98 m3
    Ok what do you have for a tune?
    What cams?
    What fuel/compression? Boost?
    Post a dyno graph? If it’s a standalone what’s your vanos setup?
    1989 535i - sold
    Nov 2009
    italy
    325i e36
    Log
    Hello
    Cam are catcams for turbo conversion
    270/250
    Fuel is ron 95
    Here log
    https://youtu.be/DtURfXHwmPM
    Stock intake manifold and throttle body
    Now i get about 530 hp and 670 nm
    Ps lifter are hydraulic
    Nov 2013
    Gerrrmany
    E21 M50 Turbo
    What happens if you raise the boost? i think 530hp is plenty for just 1,3 bar of boost.
    Whats the compression? i could imagine it would start to knock somewhere around that power level on pump fuel. what does your exhaust system and exh. mani look like?
    1982 E21 323i
    M50B25 Turbo
    Borg Warner S362 SX-E
    ECU Master Emu
    Nov 2009
    italy
    325i e36
    Here è uno graph as yu can see something
    Apr 2006
    Minnesota eh?
    86 325es
    Looks like its breaking up or there is a valve control problem.
    Nov 2009
    italy
    325i e36
    Hello
    I am sorry what do you mean breaking up or valve control?
    I have cat cams for turbo conversion 270 250 with stock head and stock hydro lifter and stock valve.
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    What's the clutch setup in the car? Do you have a log file of the pull?
    Nov 2009
    italy
    325i e36
    Hello in link Youtube in previous post you can see log
    I use f1 Cooper clutch.
    Engine has eagle rods and wiseco piston
    Cr is 8:1
    Apr 2006
    Minnesota eh?
    86 325es
    Hello
    I mean it looks like its missfiring above 5000 rpms or the valves are floating due to not enough spring pressure. What is the spark plug gap? It could also be slipping the clutch or spinning the tires.
    Nov 2009
    italy
    325i e36
    hello
    Is common problem valve float on m50 turboed?
    On rpm gauge i not see strange rpm jump usual when clutch slip.
    same for tires...when it slip i feel big black smoke but i not feel it
    spark gapped at 0.4 mm but on afr log i not see strange behavior of afr.
    what yu can see on video i posted boost has little fluctuation
    Apr 2006
    Minnesota eh?
    86 325es
    hello
    Is it a vanos or non vanos cylinder head? I can't really tell much from your video but I do see the AFR and pulse width fluctuating slightly. I also noticed that the torque drops off sharply at 5200 rpm on the graph but the log shows the pulse width is still increasing till nearly 6000 rpms. Something is not quite right there. I think I would try a different set of coils, boots, and spark plugs
    Nov 2009
    italy
    325i e36
    engine is non vanos
    but i have bought used head on ebay
    i do not know how check if from vanos or not engine
    is useful play dwell?
    dyno is lps2510 cartec rated for 400 kw
    Apr 2006
    Minnesota eh?
    86 325es
    Non vanos heads have double valve springs and vanos heads have single springs. If you do have a vanos head the cams you have might be too aggressive for the single valve springs. I think that’s unlikely the problem but it’s a possibility so I wanted to mention it.
    What dwell are you using now. The stock coils work best with about 4.5ms dwell while in boost
    Nov 2009
    italy
    325i e36
    i open valve cover and check.
    dwell is 2.5 or 2.7 as i remember i check also
    ps dropping down of power was present also with stock cam
    Nov 2009
    italy
    325i e36
    hello i checked and
    i see 2 spring one inside other
    dwell is fixed at 2.7 mm and spark
    duration 0.9
    i attach screenshot and photos
    Nov 2009
    italy
    325i e36
    Nov 2009
    italy
    325i e36
    Nov 2009
    italy
    325i e36
    Nov 2009
    italy
    325i e36
    how many mm do you sugfest for gapping plugs?
    Apr 2006
    Minnesota eh?
    86 325es
    between .4 and .5 mm
    Nov 2009
    italy
    325i e36
    what do you think about spring and dwell?
    Apr 2006
    Minnesota eh?
    86 325es
    Springs are fine. Try using a dwell table with 2.5ms at 100 kpa and under and 4.5 ms at over 100 kpa
  1. Replies: 3
    Last Post: 02-02-2015, 07:44 AM
  2. FS: E36 stock intake manifold, throttle body, and air box
    By 97flgst in forum Engines, Performance Parts & Software
    Last Post: 09-08-2009, 10:33 PM
  3. obd2 intake manifold and throttle body
    By TYE in forum BMW Parts For Sale
    Last Post: 05-09-2003, 12:19 AM
  4. WANT: OBD1 intake manifold and throttle body
    By Bernanke in forum BMW Parts Wanted
    Last Post: 03-05-2003, 08:01 PM
  5. FS: Stock Intake Manifold '98 M3 (more)
    By DMD///M3 in forum BMW Parts For Sale
    Last Post: 03-22-2001, 09:19 AM
