Hey guys,
Anyone run into this problem before? In short, when I set the right turn signal, the hazard lights turn on. This happens about half of the time. The other half of the time the right turn signal operates normally.
The left turn signal works just fine.
Ismael
Sent from my iPhone using Tapatalk Pro
Not sure but I have a sorta similar problem too. The guy before rigged some kind of front halo lights and custom brake/tail lights. I’ved replaced the fronts but need to replace all rear lights to fix the back. My problem which will hopefully be fixed once stock lights are replaced, is turn signals don’t work when headlights are on. Work fine when lights aren’t on but as soon as the headlights are turned on both turn signal lights come on on dash and stay on but no function from exterior lights.
Hey shogun,
It's happening on a 95 850csi...
I haven't edited / updated the 'My Cars' in probably 10 years
Ismael
crash control relay? https://www.bimmerforums.com/forum/s...=crash+control
