Results 1 to 2 of 2
Thread: HELP BMW shutting off randomly, CARLY APP CODES INCLUDED
    Dec 2018
    texas
    535i
    2012 bmw 535 I v6 and I think it has the n55
    Hello everyone. I've been looking for help for my sister's car issue since 5 months ago. taking it in for service is very costly for college student and cant afford it as of yet and was hopping if there anyone here who can help with the issue.
    the car was bought from an insurance auction with deplored airbags.
    I fixed main airbags and just disconnected the rest, replaced battery and disconnect cable that disconnect the engine from the battery in the trunk. the car worked fine until 5 months ago.
    THE ISSUE IS HERE
    struggle to start but its fine after starting. even fine to drive but few fox said it might be in limp mode since check engine is on.
    the car started struggling to turn on with very low rpm at start when the weather is cold, today the weather was little warm I started it with no issues just a little low rpm at start for few seconds and after that everything worked fine.
    it has oil gasket leak and some visible oil around the spark plug area, not much just little oil and it always been there since 1 year ago when she bought the car.
    I got Carly adapter and the below codes are the fault codes. oil is what recommended for my sisters model and the oil level is at middle between min-max
    getting a bmw was the worst idea she have done and we just want to get it back running to be able to use it again as its been sitting on the side of the street for few months now. I start it ones every week to charge the battery and check oil lvl.
    codes are below. please let me know if I need to provide anymore info as I can even record youtube videos of whatever area you need me to show. thank you for reading.
    Fault Report - Carly for BMW
    FV
    Base: F10
    Build-Year: 2012
    Faults: 137
    ECUs: 28
    Filter: just found
    Model: 5 (F10, F11, F18) Automatic engine recognition (MotorID=994, Parameter=159)
    Battery: 14.5V
    ADDITIONAL OBD: OFFNormal communication
    Normal connection
    normal
    B 2
    Date: 2018-12-23 15:22:43
    Carly Adapter
    Motor Control:
    Engine / Motor
    Radiator shutter, top: upper stop detected early
    Code: 138701
    Throttle angle - intake manifold absolute pressure, Comparative pressure too low
    Code: 101F01
    Mixture Control: mixture too lean
    Code: 118001
    Tank ventilation system shut-off valve, control: Line break
    Code: 191B04
    Tank vent valve control: Line break
    Code: 191004
    Tank vent valve control: Short circuit to earth
    Code: 191002
    Start voltage transformer / starter generator, control: Short circuit to earth
    Code: 218402
    DMTL solenoid valve control: Line break
    Code: 190004
    DMTL leak diagnosis pump control: Line break
    Code: 190704
    DMTL solenoid valve control: Short circuit to earth
    Code: 190002
    DMTL, Heating, control: Short circuit to earth
    Code: 190502
    DMTL leak diagnosis pump control: Short circuit to earth
    Code: 190702
    Mixture Control: mixture too lean, large deviation
    Code: 118401
    Power Management: Consumer reduction active
    Code: 213901
    Air mass plausibility: air mass to low
    Code: 102002
    Motor Control:
    Central Gateway / zentrales Gateway
    Prerequisite reset terminal 30F Alarm Clock
    Code: 801C10
    Application shutdown Terminal 30F Alarm Clock
    Code: 801C11
    Faulty asleep 30B
    Code: 801C15
    Central memory full error
    Code: 801C20
    ABS / DSC / Brake:
    Dynamische Stabilitäts Control / DSC
    Severe undervoltage Local Power
    Code: 480964
    Left Front - Air Gap Too Big wheel speed sensor
    Code: 4809A8
    Under-voltage power supply Global
    Code: 4809AB
    Rear left - Failure Mode Since permanent error suspected wheel speed sensor
    Code: 4809B1
    Back Right - Failure Mode Since permanent error suspected wheel speed sensor
    Code: 4809BA
    General - Existing few seconds suspected error 2-3 Rdf temporarily incurable error -
    . Wheel speed sensor
    Code: 4809D3
    Error message
    Code: D35557
    Error message
    Code: D3556D
    Error message
    Code: D35744
    Error message
    Code: D358E1
    Error message
    Code: D35B3F
    Error message
    Code: D35586
    Hand brake / Feststellbremse (EMF)
    ECU OK, no Fault Code
    Airbag:
    Crash safety / Airbag
    Resistance to large pockets driver Stage 1 - SC1
    Code: 930904
    Resistance to large bags Driver Stage 2 - ZK2
    Code: 93090A
    Driver airbag resistance too large valve - ZK3
    Code: 930910
    Resistance to large pretensioners driver - ZK7
    Code: 930928
    Resistance to high load limiters Driver - ZK9
    Code: 930934
    Short circuit to ground head airbags right - ZK24
    Code: 93098B
    sorry, unknown fault
    Code: 930BB9
    Code: C95418
    Code: C95419
    Code: C95432
    Transmission Control:
    Getriebesteuerung /Transmission
    Error message
    Code: CF1461
    Error message
    Code: CF1501
    Error message
    Code: CF1511
    Error message
    Code: CF1521
    Error message
    Code: CF1531
    Error message
    Code: CF1541
    Gear switch / Gangschalter
    Error message
    Code: E09424
    Instrument cluster:
    Instrument cluster / Kombiinstrument
    After a short Ub Tank Sensor links
    Code: E12C01
    After a short Ub-tank sensor right
    Code: E12C03
    Error message
    Code: E1145B
    Error message
    Code: E1145C
    Error message
    Code: E1145E
    Error message
    Code: E11474
    Error message
    Code: E1147A
    Error message
    Code: E11480
    Undervoltage detected
    Code: B7F685
    System time is set back
    Code: B7F668
    Error message
    Code: E11498
    Error message
    Code: E12C1C
    Redundant data in Cas Filed
    Code: B7F665
    Error message
    Code: E114A6
    Error message
    Code: E12C21
    Errors in gear position, gearshift point indicator-messages-Can (recognized by the
    graphics card)
    Code: B7F68C
    Error message
    Code: E12C2B
    Code: E11467
    Code: E12C38
    Central info display / Zentrales Display
    Code: 800370
    Zentrales Info Display hinten rechts
    ECU not present/no response from ECU
    Head-Up-Display
    Light/Rain Control:
    High beam / Fernlicht
    Heating / AC:
    Air conditioning / Klimaanlage
    Code: 80120D
    Error message
    Code: E71402
    Error message
    Code: E71406
    Error message
    Code: E71413
    Error message
    Code: E71415
    Error message
    Code: E71416
    Error signal
    Code: E71429
    Error message
    Code: E71448
    Aircon rear /Klima Heck
    Immobilizer System:
    CAS
    Code: 930769
    Code: 93076A
    Code: 93076B
    Code: D91410
    Park distance control:
    Park Distance Control / PDC
    Error message
    Code: E21407
    Cruise Control:
    Active cruise control / Aktive Geschwindigkeitsregelung
    Sunroof / Roof:
    Roof / Dach Funktionen
    Error message
    Code: DE9406
    Engine is not started by overvoltage / undervoltage (FAH)
    Code: 801A38
    DWA-mail alert details in the alarm memory
    Code: 801A3A
    Shd: Invalid property, no normalization presence
    Code: 030215
    Esh: Invalid property, no normalization presence
    Code: 030295
    Sine: External power supply
    Code: 801A4B
    Sine: Inclination Sensor defect
    Code: 801A51
    Deactivation IRS and inclination sensor by customer function
    Code: 801A4A
    Audio/Navi/Communication:
    Interior camera/Innenkamera
    Top_Rear_Side_View_Kamera
    Code: 800B9F
    Timeout
    Code: CA940A
    Rear Entertainment /Entertainment hinten
    Multimedia-Changer / Wechsler
    Telephone
    Digital Satellite-Tuner USA
    Central control rear/ Zentrales Bedienelement hinten
    CD-Changer / Wechsler
    Driver assitant / Fahrerassistent
    Seats:
    Driver seat rear /Sitz Fahrer Heck
    Rear seat passenger/ Beifahrer Sitz hinten
    Driver seat /Sitz Fahrer Heck
    Code: 8029D4
    Code: 802A1E
    Seat passenger/ Beifahrer Sitz
    Code: 802C1E
    Systems:
    Junction Box
    Short circuit to ground or open circuit - battery sensor, WakeUp line (WUP)
    Code: 8020DB
    30F terminal reset / shutdown
    Code: 8020E8
    Missing LIN Slave - K-LIN 6 xAUC sensor
    Code: C90D74
    Fuel pump / Kraftstoffpumpe
    Nightvision
    Central Control / Zentrale Bedieneinheit
    Code: 801405
    Tire pressure control / Reifendruck
    HDD des CIC
    Anti-theft alarm system:
    Video Switch
    Chassis:
    Steering switch cluster / Schaltzentrum Lenksäule
    Air suspension / Luftfederung
    Dynamic vertical / vertikale Dynamik
    Body:
    Steering / Aktivlenkung
    Trailer / Anhaenger
    Fussraummodul /FRM
    Environmental error (Over-/undervoltage overtemperature headlight driver module
    (TMS) Links
    Code: 800FC5
    (TMS) Right
    Code: 800FC4
    Data error or timeout headlight driver module (TMS) Links
    Code: 800FC3
    Mirror undervoltage
    Code: 800FB9
    fog light fault
    Code: 800F3A
    fog light fault
    Code: 800F3B
    Has fog output short circuit left
    Code: 800F3C
    Welcome Light-repeat active
    Code: 800F92
    Lighting the active-repeat
    Code: 800F93
    ELSV undervoltage
    Code: 800FA8
    Error message
    Code: E58500
    Error message
    Code: E58501
    Error message
    Code: E58503
    Error message
    Code: E58510
    Error message
    Code: E58511
    Error message
    Code: E58507
    Lm Lin bus error Tms links
    Code: 800FC8
    Integrated Chassis Module / Längs+Querdynamik
    :Global supply voltage external
    Code: 48279B
    Error message
    Code: D01646
    Error message
    Code: D01744
    :Error message
    Code: D02C67
    Error message
    Code: D018E1
    Error message
    Code: D02D54
    Error message
    Code: D01557
    Error message
    Code: D02D58
    Error message
    Code: D01558
    Error message
    Code: D0156D
    Error message
    Code: D01570
    Error message
    Code: D01B3F
    Error message
    Code: D01A08
    Axle rear / Hinterachse
    Roller left /Aufroller Links
    Roller right /Aufroller Rechts
    Tailgate / Hecktuer
    Damper front left / Rad vorne links
    Damper front rechts / Rad vorne rechts
    Damper rear left / Rad hinten links
    Damper rear right / Rad hinten rechts
    Other:
    Tire pressure control / Reifendruck Kontrolle
    Steering /Lenkung
    :Power supply - Local undervoltage reduce steering assistance
    Code: 4823FC
    Code: 4823FF
    Code: D518E1
    :Error message
    Code: D51744
    :Error message
    Code: D51C1B
    :Error message
    Code: D51C1F
    :Error message
    Code: D51414
    Flexible Bus-Interface / Schnittstelle
    Car Communication Computer CCC
    :All function blocks Registered most nodes
    Code: E1C447
    :Monitoring circuit reset was triggered
    Code: E1C440
    these are 2 videos of some vacuum in the engine when removing the oil cap.
    https://www.youtube.com/watch?v=abg-TqHIT9w
    https://www.youtube.com/watch?v=VvqWptSmEdI
    Jan 2016
    Ca
    2001 525it
    You need to take it to a good independent BMW shop for diagnosis
  1. Help! BMW business CD radio stuck in code wait mode
    By mantu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-10-2015, 11:48 AM
  2. BMW say there is no Radio Code for my car! Help!
    By halenko in forum 1995 - 2001 (E38)
    Last Post: 09-07-2012, 06:54 PM
  3. My bmw shuts of randomly
    By genti530i in forum 2004-2010 (E60,E61)
    Last Post: 01-16-2012, 09:42 PM
  4. help bmw 318i e36 track car wiring diagram needed
    By dal uk in forum 1991 - 1999 (E36)
    Last Post: 02-07-2010, 07:58 PM
  5. CODE WAIT - Radio locked - Help need tunes in the car
    By mbadger in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 07-22-2008, 06:54 AM
