Results 1 to 22 of 22
Thread: Ok guys, I need suspension setup advice.
    Dec 2012
    NC but always everywhere
    '99 BMW M3 Coupe (Dakar)
    Hey everyone, I've posted a few questions in the past regarding suspension and camber arms etc to try to get a little advice on what to purchase along the way and now I'm at the point where I am ready to install everything. I love driving my car fast and keeping it clean. That said, I know a little about the mechanics but not near enough not to ask for advice....so here is the skinny:
    99 M3 Coupe. Right now I am on stock M Contours with Bilstein Sport Shocks and Eibach Sport Springs. I recently purchased KW V2 coilovers, Turner rear adjustable camber arms, and Turner fixed camber plates for the front. For not I am keeping the stock wheels, I just want the car to be lower. It still has a bit of the raked look with the Bilsteins and I want to get rid of that. I want the car to sit lower (finders sitting just at the top of the tire) and I want the car to handle well and not rub. As I stated in a previous post, I do run spacers on the front and the back. 15mm front and 10 or 12mm in the rear (can't recall). When the car is fairly full of fuel and the rear is compressed I get a slight rub at the top of the arch. I'm hoping the rear camber arms will get rid of this as there is not a lot of negative camber in the car now. This car is not a daily driver. She is a have fun on back roads on Sunday and take to Cars and Coffee car so I am not worried about tire wear but I am worried about handling and performance.
    OK....all that said, can anyone provide me with the specs you think I'll need to set up the car correctly? Castor, camber, and toe for all four wheels?
    All advice is appreciated! Thank you!
    Dec 2012
    I want mine to sit like this stunning Estoril Blue M3.
    Feb 2002
    Honolulu, Hawaii
    1997 M3, 2dr/5spd*
    Estoril/Modena '97 M3...sold for the second time.
    You only live once, and I'm running out of time...
    Dec 2012
    Quote Originally Posted by Gene V View Post
    Thank you Gene.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Running close to zero or at zero toe is fun and engaging, but can be a handful. Definitely more tail happy.
    Caster is generally not adjustable, though your camber plates may provide for it (the Vorshlag ones do, not sure about the Turner ones you've got).
    The Definitive Alignment Guide above is pretty much the E36 Alignment Bible at this point.
    Dec 2012
    Quote Originally Posted by blckstrm View Post
    Thanks. And dig those wheels
    washington dc
    Avus Cosmos Calypso!
    don't run zero rear toe. You are asking for trouble...
    FL
    are slow.
    That Estorial M3 is honestly too low for daily driver status, or even track duty. It really should be about 1/2"-1" higher than that. The front is probably resting on the bump stops if it still has stock tap hats. If you go a full coilover setup, you might gain an inch of travel which would allow it to sit that low. You'll find that it will handle better when the suspension is given room to do it's work. (Let the hate begin).
    Zero toe upfront, around 2.5-3 degrees negative camber upfront.
    I ran exactly what Joey did in that post:
    Front
    Camber: -3.5 deg per side
    Toe: 0 (0.10-0.20 total toe out for autox)
    Rear
    Camber: -2.0 to -2.5 deg per side
    Toe: 0.20 total toe in (IIRC this is 1/8" total toe in)
    With coilovers and a UUC front sway bar. Honestly the car felt like I could turn in at some ridiculous speeds. Inspired a lot of confidence.
    One of my M3's had Bilsteins and H&R sport springs, I feel like it rode like crap... I really never liked those shocks.
    -Dr. Seuss
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by Hova View Post
    What?! That is a fairly mellow drop depicted.
    Dec 2012
    Front
    Rear
    Thanks for the advice. First, I Fn love that Estoril blue car depicted. That's EXACTLY how I want mine to sit. Keep in mind, mine is absolutely not a daily. Hell it's never even been in the rain. I do have a UUC front shick tower strut bar ironically as well as Turner front and rear sways. Glad to hear you like the way yours rides.
    Dec 2012
    Quote Originally Posted by Braymond141 View Post
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    It's not the ideal height if handling and handling characteristics as good as stock if not better is a goal.
    The OP suggests that he's in it for the Cars and Coffees, so it doesn't matter. Unless there's a speed bump at Starbucks.
    88M3 AW 43k miles Project FS
    Dec 2012
    Quote Originally Posted by MauiM3Mania View Post
    It's not the ideal height if handling is handling characteristics as good as stock if not better is a goal.
    I am super careful when it comes to parking lots and speed bumps. Above all I'm a driver. I want the car to handle and to handle well.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Can’t run spacers in the rear on a 96-99 with stock wheels.
    Jan 2002
    Central Pacific
    Quote Originally Posted by Rooster20 View Post
    Right on. Do a search using e36 m3 solo and winner and check the ride heights. No competitive car sit low as the car in the second post of this thread.
    As I understand it, you're not competing and hope you don't drive at 10/10's on public roads making the ultimate suspension set up unnecessary. So do what you want for the appearance. Coilovers allow the height to be adjusted, but different spring heights would be needed to accommodate a 'handling' set up and another for the dropped look.
    Dec 2012
    As I understand it, you're not competing and hope you don't drive at 10/19's on public roads making the ultimate suspension set up unnecessary. So do what you want for the appearance. Coilovers allow the height to be adjusted, but I different spring heights would be needed to accommodate a 'handling' set up and another for the dropped look.
    Will do, thanks
    Dec 2012
    Got the V2's installed. Waiting for the car to settle a bit more and then figure out exactly where I want her to sit. Think we got the camber right. Had to pull the rear spacers. If I rolled my fenders they'd probably still be ok but terrified to mess with the paint.
    What do you guys think so far?
    Dec 2012
    Oh, also going to sell my other suspension if anyone is interested.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I like your garage and the car inside
    Jan 2006
    Oakhurst, CA
    I like the concrete finish. What process?
    Dec 2012
    Quote Originally Posted by Mless5 View Post
    Thank you. There are a few other babies tucked away in there too. Garage is still a work is progress. It was my "I've been to Afghanistan too many times not to build what I want" garage. You can see the stuff that needs to be hung. It's coming along though.
    Dec 2012
    Honestly just a natural finish. They got the floor pretty smooth from the start and it turned out nice. Only thing I'll probably do someday is put some sort of protective clearcoat on it. Otherwise I just keep it clean. 😊
  1. Need full suspension setup advice for street/track
    By highboostingm3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 06-18-2007, 01:18 AM
  2. ok guys, I need some advice....
    By JBgotM in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-16-2005, 05:09 PM
  3. Newbie need track setup advice with sway & tire pressure
    By JT-KGY in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-16-2003, 06:37 PM
  4. Replies: 18
    Last Post: 09-13-2002, 08:49 PM
  5. Need Suspension upgrade advice
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 06-01-2001, 10:29 AM
