Results 1 to 15 of 15
Thread: 2002 M3 resurrection
    Aug 2018
    columbia sc
    2002 CSM M3, 1997 m3
    Bought this car in the summer of 2018 after owning a WRX for 3 years and an e36 M3 for 3 months. Loved the e36, however my example was a bit rusty and had major interior issues. After selling it for $6500 I was looking for a ďdealĒ on an e46 m3
    Thatís when I found this bad beeeech
    This turd was posted on craigslist about 3 hours from me for $4500. I offered the owner $3300 and went to look at her.
    Thankfully when I was down in Atlanta where the car was, I found an s54 for sale for $2700 without accessories. Rod bearings done, vanos done!
    Aug 2018
    columbia sc
    The car was a 2002 carbon black on black SMG M3 with 207k miles. The previous owner stated it may have a bad head gasket and that it refused to run. So right off the bat I assumed and budgeted that it will be needing a motor.
    So after a day of thinking and moving money around I picked her up, and loaded the motor in the back of my 3rd gen 4runner!
    The 4 hour drive home without trailer brakes, a leaky trailer tire and a less then stellar tow setup was less then ideal, but the thought of driving my childhood dream car got me through it
    Aug 2018
    columbia sc
    As stated, thankfully I budgeted and negotiated assuming the car would need a motor, as it turns out, the POís kid cousin had thrown a rod through the side of cylinder 6...
    After I discovered the catastrophic motor failure I set into motor swap mode... this was done in the dirt, on jack stands. Not recommended but very possible.
    Aug 2018
    columbia sc
    After battling with the oil pan on the steering rack, I discovered if I lowered the front subframe an inch or two on the bolts without taking them out, I was able to pull the motor and install the new one way easier.
    So I got the new motor in, went to start the car, and had no starter noises, and a Xmas tree dash... after two days of trouble shooting I realized I had mixed up the smg ecu and dme plugs. After I fixed that she fired right up!
    First drive!!!
    At this point the car had 0 power steering assist, so I replaced the pump... 3 times... after pick a part ran out of 330 pumps, I had to take apart the system, finding that the return (I think) banjo bolt had a check valve completely stuck in it, starving the pump.
    Finally had a fully functional car! And promptly took it to the mountains
    Aug 2018
    columbia sc
    Mixed matches rims were the consequence of a $100 set of 18s found on CL, and two bad front tires on my 19s... after I decided the car wasnít going to bleed my bank account anytime soon, I bought a full set of 255/35/19 firehawk Indy 320 TW tires. These things kick ass!!! Rebranded potenza 003s from what I can tell. I ran them on my wrx and loved them. To fit the 255 square I am running a squared set of 19 inch rears.
    Aug 2018
    columbia sc
    During the two months I was working out the kinks after the motor swap, which lead to
    - a starter replacement $180
    - water pump replacement $160
    - TPS $60
    - previously mentioned PWST pump replacement $100 spent on 3 330 pumps
    All these things were replaced because of failure all within the month... at this point I wasnít to fond of the car... however I think this will help me fall back in love with it...
    Full manual conversion WITH a stock manual box.
    - full manual tranny with linkage $700 (70k miles)
    - used pedals+sensors+lines+slave out of a crashed m3 for $100
    - rear shift bushing and support from ecs $46
    So Iíll be in my swap around $900 as long as nothing goes horribly wrong!
    Salem, MA
    03 zhp, 97 e36m3, 04 zhp
    You'll be fine, glad you are keeping her on the road!
    Compactive's Avatar
    Compactive is offline Helpful. BMW CCA Member
    Moderator
    DMV
    3x 318ti
    Heck of a rebuild, keep it going!
    RIP Ted.
    Want a custom signature? Post requests here, or PM me here | My Flickr
    Aug 2018
    columbia sc
    I currently have a broken leg, so no m3 for me for at least another month.. hereís another picture of the blue turd the day after my buddy bought a new gti. Ran up and down the blue ridge to celebrate him getting out of his high school truck. Hopefully Iíll get the tranny swap done in my down time
    Aug 2018
    columbia sc
    Forgot about this thread...
    So Iím the past months Iíve completed the tranny swap, replaced a fuel pump, and competed in my first few autocrosses.
    Iím finally starting to bond with the car, and all this work is becoming worth it..
    My next goal is to pickup a set of 17s that are offset enough to look good on the M. This is proving impossible without buying something new so expect apex arc8s soon. Iíve been hoarding 255/40/17 re71rs in the meantime
    94 325i, 95 M3, 1997 325
    Very nice man looking good
    Washedit1 by thedude60526, on Flickr
    11/10's Racing
    94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
    May 2015
    Colorado
    E36 / 2002 / XJ / DR350
    Been there before OP. Always worth it in the end.
    Wanted
    Schrick M50 NV intake cam
    E36 X-Brace
    E36 AA Exhaust
    Aug 2018
    columbia sc
    Was having some clutch slipping issues, which I thought was weird because I had the clutch out 3k ago and it looked fine...
    Turns out the transmission input shaft seal was puking pretty good and ruined the clutch disc. You can see the oil collected on the flywheel in the second picture.
    So Iíll be throwing in a new clutch kit/flywheel
    On a positive note I found a set of 17s for $170 that will work good. X8 et 20 and x9 et 26. Iíll be running the 9s up front and the 8s in the rear with a 20mm spacer.
    Aug 2018
    columbia sc
    Got my track wheels mounted. Re71rs & Style 66s.
    rears in the front.
    Fronts in the rear with a 20mm spacer.
    Aug 2018
    columbia sc
    Third autocross event and she did well! The re71s have a lot more grip and felt great.
    Car took a beating from myself and three other drivers will no major issue.
    Alternator low voltage light keeps coming on intermittently so Iím thinking Iíll have to get a new one soon.
  1. Need help for Hill Recognition on 2002 M3 SMG
    By BJBMW2 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-20-2002, 06:19 PM
  2. Need help on Hill Recognition for 2002 M3 SMG!!
    By BJBMW2 in forum 2001 - 2006 M3 (E46)
    Last Post: 06-18-2002, 09:07 AM
  3. Anyone know what the differences might be between a 2003 and 2002 M3?
    By dysphunxion in forum 2001 - 2006 M3 (E46)
    Last Post: 05-29-2002, 10:15 AM
  4. Went To a Driving School Today.......And Got To Ride In An Instructor's 2002 M3 SMG!!
    By jmciver in forum General BMW sponsored by Intercity Lines
    Last Post: 03-09-2002, 09:23 PM
  5. Car Comparison: 2002 M3 vs 2002 CLK55 AMG
    By euro_imports_21 in forum General BMW sponsored by Intercity Lines
    Last Post: 03-01-2002, 06:52 PM
