Results 1 to 3 of 3
Thread: A/C compressor pump seal replacement
    Mar 2014
    Victoria, Australia
    1993 E32 740iL
    Hi Guys,
    My a/c compressor has started to leak from the front seal, and as the pump is still good, was wanting to just replace the front seal.
    Has anyone here attempted and/or succeeded to replace a front seal, and have any advice for me? as I would like to know if it is a simple procedure, or whole pump dissassemled.
    Thanks in advance,
    PJ
    Jun 2010
    TX
    1983/84/85 745i
    Thumbs up
    MT2052 is the shaft seal kit.
    There is a case seal kit available too, I would advise using it also while the compressor is out of the vehicle. The seals are HNBR...and are not 35 years old.
    I make E23 parts.
    10/1984 745i
    11/1984 745i
    11/1984 735i (10:1-265/6)
    Mar 2014
    Victoria, Australia
    1993 E32 740iL
    Thanks Hitman, will get the case seal kit also
  1. Can power steering pump seal be replaced?
    By twomanyprojects in forum 1991 - 1999 (E36)
    Last Post: 03-05-2011, 11:56 PM
  2. transmission rear output seal replacement
    By supark in forum 1991 - 1999 (E36)
    Last Post: 11-16-2007, 01:03 PM
  3. Water Pump Need Replacement???
    By Al/325is in forum 1992 - 1999 M3 (E36)
    Last Post: 05-18-2007, 05:33 PM
  4. crankshaft seal replacement
    By mti in forum 1991 - 1999 (E36)
    Last Post: 01-20-2005, 04:03 PM
  5. Vavle Seal Replacement
    By maxxedout in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2004, 03:47 PM
