Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 126
Thread: After Hours Autosports E36 Pro-Am build
  1. #26
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Nice work. Wish I had painted my bay
    instagram @andyitslit
  2. #27
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Novablue454 View Post
    Exactly, its just a damper, I guess only the LS2 came with them? The LS1/LS6 don't have anything. Some people were saying to just run with nothing but that sketches me out.
    It looks like Duraflex makes some fiberglass ones for the E36 Sedan, I'd prefer plastic/poly personally though
    https://www.carid.com/duraflex/rbs-s...QaAtcJEALw_wcB
    Thanks!!
  3. #28
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    She's back with a painted cage and interior!
    Untitled by novablue454, on Flickr
    made new brake lines (found out now these won't work, dangit. More on that later)
    Prop valve mounted
    Engine / Trans are in!
    Couldn't resist mocking up the intake with the new hydrodrip and radium rails, as well as the new MSD wires and boots
    Clutch line installed and bled with this trick dry-brake line for easy trans removals if needed
    Steering shaft re-installed
    ARC 8000 w/ Oil Pressure Safety relay board mounted
    ECU Mounted
    Hydro re-installed with new dual caliper master
  4. #29
    Mar 2011
    PNW
    LS E46
    That intake is money.
  5. #30
    fairfax,va, usa
    2 E30s and a maxima
    whats a dry brake line? That looks useful.
    Edit: https://www.brmotorsports.com/alumin...oupling-2.aspx
    Disconnect and reconnect and wont put air in your lines. Wow. Thats so cool.
  6. #31
    Nov 2018
    Westland, MI
    2002 E46 325i
    This thing looks awesome! Great work
  7. #32
    Mar 2011
    PNW
    LS E46
    It’s dry-break, they’re what’s used on heavy machinery for auxiliary attachments. Didn’t know they used them for cars, kind of cool. They still let a little bit of air but it’s negligible - but I wouldn’t want to keep disconnecting it unless it was absolutely necessary.
  8. #33
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Yep, hopefully won't ever need to use it, but the previous an fitting threaded directly in at the firewall in combination with the previous abs delete set up made removing that hose to pull the trans a nightmare. I spent like 45 minutes just on that line making 1/16 of a turn at a time with a box wrench. Now it should be easy and take minimal bleeding which is good, because the hinson speed bleeder we put it sucks.
  9. #34
    Mar 2011
    PNW
    LS E46
    I’m switching to a t56 and was gonna get that hinson bleeder - don’t bother?
  10. #35
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Quote Originally Posted by Liquidity View Post
    You definitely need one, but I'd go with Monster or Tick. This one came with the wrong fitting to the TOB and they wouldn't send the right one, my buddy got the same one and his had the right fitting but it was very poor quality and we ended up replacing it anyway, and it pulls air in through the swivel at the speed bleeder while you're trying to bleed it.
  11. #36
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    got the rest of the wiring bits mounted
    made this cart to make wiring a little more organized
    mounted the new expansion tank to the old catch can bracket and mounted the overflow, also got the hvac delete installed
    got the oil coolers mounted in a well protected space
    also not pictured but got the front brake lines remade and bled!
  12. #37
    fairfax,va, usa
    2 E30s and a maxima
    Might steal that wiring holder idea.
  13. #38
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Quote Originally Posted by protomor View Post
    I stole it from someone else haha, took all of 15 minutes to weld some scrap steel to the cart and luckily had some scrap tube the perfect size. The hard part is going to be keeping them nicely spooled once the plastic comes off, I might have to drill holes around the spools like how mig wire comes
  14. #39
    Mar 2011
    PNW
    LS E46
    Rubber bands.
  15. #40
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Starting to figure out some wires
    Engine bay harness is done, needs a little zip tie organization still. Engine harness is also all hooked up with 58x converter, flat touch knocks (re pinned PCM) and other extensions.
    Theoretically I'm done in here other than throwing the intake on and plugging in the headlights/fan once they're on
    Installed the HARD rear block offs and painted the package tray
    Starting the fuel cell mounting but I ran out of material
  16. #41
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Racepak mounted, I mocked it up in the factory dash, should sit just right and look nice in front of the HARD cluster delete panel
    Racepak harness made and ready to install, the blue wire needs to go with the fuel pump wiring to the trunk so it is not loomed yet, and the final location of the switches for the other two wires wrapped up still needs decided.
  17. #42
    Mar 2011
    PNW
    LS E46
    I bought one of those little dry breaks for my trans, too. What a great idea.
  18. #43
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Swapped out the Bimmerworld RTABs for the Nerp Offsets. Last season I was only able to manage to get 1/8" toe out in the rear, so hopefully this is enough to get some toe in. If not, We'll be adding the Xcessive offset brackets.
    This beauty finally arrived!!!
    Swapped the old Condor bushings over and mocked it up. It's going to take some clearance work, but not as much as I was expecting.
    Also got the rest of the wiring mostly ran, need to hook up the battery and test everything before I pull and loom it all but caught up in daily work this week. Also got the Radium FPR mounted and fuel line stuff ordered, so that should be happening soon!
  19. #44
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    and shes in!
    4.12 gears installed to start
    Realized its going to have to come back out to get the arms bolted up but no big deal, just good to know the clearance is taken care of.
  20. #45
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    Ya'll wanna get rid of those bimmerworld rtabs?
  21. #46
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Arms are installed and sub is back in. We decided to start with the supplied 4.12 gearset and go from there so went ahead and filled it. Damn thing takes almost 4 qts!
    Battery box is in and cabin wiring is done, just need to make the single harness to the trunk.
    Starting on some fuel lines, Radium regulator mounted.
    got the new nose panel trimmed and installed, starting to make oil cooler lines
    new remote filter mount with gauge port in it
    Turn1 custom PS pump showed up!
    Fuel cell mounting is almost done. Just need to mark / drill / riv-nut the top edge to bolt the fuel cell down to it. Also has mount for small sprayer tank and fuel pump relay box on it.
  22. #47
    DeWitt, Michigan
  23. #48
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    I wouldn't mount the oil filter relocation setup in the in the wheel well like that. IMO any fluids/ coolers/ lines should be mounted between the frame rails whenever possible for safe keeping.
  24. #49
    fairfax,va, usa
    2 E30s and a maxima
    I also feel like a wheel might hit it.
  25. #50
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    It's been there for 3 years. It's for sure not an ideal spot, but the damn thing is massive and there's really no where else to put it. I really wish these companies making swap pans would just put the damn filter on the pan (like the holley 302-1) but for some reason you have to deal with running -10 lines through headers and mounting filters and crap. Dumb.
  1. Zionsville Autosport E36 Competition Cooling Kit Review
    By vinnymac in forum 1992 - 1999 M3 (E36)
    Last Post: 01-02-2011, 01:36 PM
  2. DSC Malfunction after hour of driving.
    By BMW323iDude in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-29-2005, 03:12 PM
  3. 1997 M3 Oxygen Sensor O2 (2 of them) after cats. (any E36 bmw)
    By AAA323IsAAA in forum BMW Parts For Sale
    Last Post: 07-12-2005, 10:29 AM
  4. Bmw performance center after hours
    By Carmageddon in forum 1983 - 1991 (E30)
    Last Post: 06-02-2005, 01:17 AM
  5. Photo after washing my e36 323is**
    By kevincao in forum BMW Rides & Events
    Last Post: 01-21-2005, 01:49 AM
