Results 1 to 14 of 14
Thread: Tig welding exhaust (stainless)
    Mar 2013
    Upstate NY
    M3
    For your butt joints are most guys using filler or just fusion welding them? About to modifiy mine and do a full exhaust for the E30. I'm having a weird problem with using filler. I've not tried fusion yet though.
    Aug 2011
    philadelphia PA
    1993 325is
    Fusion is okay if the fit-up is spot on. Mine never is so I use filler.
    Next time I want to try Solar Flux as a argon purge alternative.
    Mar 2013
    Upstate NY
    M3
    Okay, I'm still getting the feel for it, just need an auto dark helmet to perfect this. I'm running like 30-40 amps and it works okay but still making holes once in awhile lol.
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    I’m using 308 filler. Good fit up really helps. Seem stainless wants you to be FAST. Floor the pedal, get your puddle and it’s GO TIME. Otherwise you hang around and burn a hole.
    I’m running about 50 amps on .065”, messed around with pulse a little, seems to help.
    Mar 2012
    Renton, Wa
    98 m3
    So even with perfect fitup it’s best to use a touch of filler. Lay a straight edge over your fused weld if you think otherwise.
    I work small increments 3/4” at a time.
    Hot and fast. With stainless heat concentrates.
    After I cut every joint I take and belt sand them so they fit clean without burrs.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Mar 2013
    Upstate NY
    M3
    Thanks guys, I'll try all this. It will really help my next few projects. Didnt realize you had you haul a$$ with it so much. Yeah, I always feel uncomfortable when doing pipe too, always re positioning n crap.
    A house
    '86 325e, '14 VW EPA
    Quote Originally Posted by Mklock View Post
    Yeah, if you think about it, when you're welding around a circle, the moment you move the torch, you're already at a different angle (off on a tangent). So you really need to learn to change the torch angle with every step. Not only will it make your welds look nicer but you'll also have a much more consistent weld because the penetration and nugget size will start to taper as you start blowing heat at an angle. If your puddle starts looking more like a spearhead than a dime, stop. And use the weld appearance to judge your heat and speed. If you can't make it look silver or at worst straw, you need to move faster. And there's almost no such thing as too much argon. Ideally you want to have a fairly large gas lens with 25cfh (or more depending on the lens) chugging through, with significant pre and post flow (esp post). If your welder doesn't let you configure that, before the postflow stops, stab the pedal to initiate a new cycle. And if you're not comfortable going quicker/colder, then like others said, do a bit at a time and let it cool. Once you heatsoak things sufficiently, there's almost nothing you can do to not get a cooked grey weld which is trash.
    Also do all you can to get a proper purge going, let it run long enough and don't seal things airtight, leave a small vent up high to push the air out. When you're first starting the weld, the seam is enough but as you start to close it off, you'll want the hot gas escaping elsewhere or your last quarter inch of weld will turn into an Old Faithful geyser. Solar flux does the job when other options aren't practical but you should limit it to that, it's not a substitute. The back side of the weld still won't be as good as a properly purged one.
    Mar 2012
    Renton, Wa
    98 m3
    To add to the above it’s easy to mistake too little heat for needing to move faster.
    If it takes too long to puddle you’re already welding at a disadvantage. The heat has already built up too much.
    You should be able to weld a 3/4” bead start to finish in I don’t know <4 seconds? It should puddle very quick.
    You’ll find as you go up in heat, improve torch angle and then match speed and filler your welds improve drastically.
    Usually blowing a hole is from built up heat not too many amps. Food for thought.
    1989 535i - sold
    Mar 2012
    Renton, Wa
    98 m3
    Oh also I set the amperage like 25% high to get a quick puddle. 100% in to start the weld then I come back to 60% and get her back in to the correct heat.
    If you have to reposition a lot you need to get a more stable base and become more comfortable. Weld smaller sections and really focus on angle. If you can only weld 1/4” at a time just make it a routine until filler and torch become second nature.
    Sometimes I’ll weld a bit then pause let the post flow run and before it ends get back at the next section. If you’re welding hot enough and at the correct speed the metal doesn’t ever over heat. I have welded a 4” exhaust most the way around with only completing the post flow and setting the welder down maybe 3 times?
    Anyway that’s my thoughts.
    1989 535i - sold
    A house
    Yep, welding amperage and heat input are not the same thing. Heat input is the integral of the amperage. Hitting it hard and moving out adds up to much less heat than camping out forever at lower amps. I like welding very thin stuff with an initial pass using the pulser set to about 150, with 5% dc and 20-30% bg current, and WAY more amps than should be used on that thickness. Lets me fusion weld 1/16" alu and camp out as long as I want without blowing through.
    Apr 2006
    Minnesota eh?
    86 325es
    If you like to take pictures of pipes with a DSLR and Instagram filters and need people on the internet to think your cool do fusion welds. If you don’t want to have to fix it after it cracks use filler.
    A house
    Depends on the application. Edit: I assumed you're replying to me but for the OP (exhaust), agreed. But for intakes and such, I have no problem with the fusion welded, unpurged Ti and shit. They could just as well use HVAC ducts.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by TheJuggernaut View Post
    No I was replying to the OP. I use filler on almost everything, especially exhaust stuff.
    Filler is a also a useful tool for controlling heat as well since that topic was being discussed as well.
    A house
    Yeah for anything stressed, be it load or temperature swings or both, absolutely. Filler as temperature control is a great trick too, especially when fitup is questionable on thinner stuff, lay the rod in the gap and light up on it.
  1. Redoing my "TIG" welded exhaust system
    By BMW540san in forum 1996 - 2003 (E39)
    Last Post: 03-05-2016, 07:05 PM
  2. Replies: 14
    Last Post: 11-28-2015, 08:56 PM
  3. E36 Complete stainless tig welded Turbo exhaust 3 in, mid pipe back
    By xinline6x in forum Forced & Chemical Induction Parts
    Last Post: 05-09-2013, 05:37 PM
  4. E30 M5x / S5x Swapped full 3" stainless mandrel tig'd exhaust.
    By Stück in forum E30 Parts Classifieds
    Last Post: 12-27-2009, 08:21 PM
  5. 540i Custom Exhaust Stainless Steel or Not
    By batastj in forum 1996 - 2003 (E39)
    Last Post: 10-08-2004, 09:56 PM
