Hi all,
I have an error from glow plugs.
INPA shows error 13573 ... Glow System - Glow Plug - or Glow Plug Relay ...
Glow Plugs (Beru) are fine, all below 1 ohm, checked at Glow Plug Relay socket, so the wires from Glow Plug Relay to Glow Plugs are fine too.
Glow Plug Relay is new (Beru).
Still having this error and its hard to start an engine when temp. is about 0C and below 0C.
Any ideas where to look next?
I'm would check glow plug relay fuse, but have no idea where to find it.
Its a E39 530D, M57 CommonRail 1 with glow plug relay under the cabin air filter.
cheers
P.
A little update ... I have found that 100A fuse was dead (located above battery in trunk), replaced it and now Im waiting for outside temp. to go down.
