Results 1 to 7 of 7
Thread: 97 Z3 abs module suggested repair places
    Oct 2018
    Portland, Oregon
    97 BMW z3
    I need a 97 Z3 Abs module repaired, (the one that is behind the glovebox part Number 34.52-1 164 320 that is not attached to the hydraulic unit) . I called module masters and was told that they cant repair it. I called BBA Reaman and they Quoted me $425.00. I was wondering if anyone know of any different places that might be more cost effective. Any suggestion would be greatly appreciated. Also if anyone know any sources for Diy Repair that would work also. Thanks
    Jul 2010
    Ozark bumps
    00 M Roadster 17 Cayman
    If it is truly the "control unit", then IMHO (and recent experience) then I am unaware that module can be repaired (like the controller on "some" ABS pumps located in the engine compartment). Have you absolutely confirmed it is that module? You maybe able to find one from Bavarian Auto Recycling. I purchased an ABS unit (on my M the unit was not-rebuildable) and I suspect they could provide a used (1year guarantee) module at a reasonable cost (my ABS pump/module was $125 shipped). But there are others much more knowledgable on this forum that may have more insight.
    Jul 2004
    Houston, TX
    36 Cylinders
    That control unit is for the ASC+T (traction control) part of braking system.
    I would just find a used replacement. There are plenty available.
    Why do you think it needs to be repaired?
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2018
    Portland, Oregon
    97 BMW z3
    I believe the ABS moduleto be bad because I ran the Diagnostics and it said that the control module is bad as well as the hydraulic control unit. My concern in purchasing a used one is that I believe that it has to be recoded for the car, correct?, I was trying to avoid this by having my existing module repaired. If a used module is just plug and play and will work I would certainly go that route because it would be cheaper.
    Jul 2004
    Houston, TX
    36 Cylinders
    What were the exact ABS codes?
    You most likely have an issue at the pump. There is a wiring harness/ribbon inside the pump, which can crack and deteriorate causing a lot of issues.
    -Abel
    Oct 2018
    Portland, Oregon
    97 BMW z3
    I have a code 66 throttle valve actuator mechanical, an 82 code for the ABS solenoids, and a 71 for the ABS module. I'm fairly sure I will have to resolder the Abs pump ribbon, but I wanted to start with the module repair because this is my daily driver. Do you think I should start with the pump first? And see if that clears everything up? I'm not sure if the codes stack one on each other and they affect the other codes being read. I'm fairly new to electronic computers in cars I'm kind of old school.
    Oct 2018
    Portland, Oregon
    97 BMW z3
    I Figured it out, was a relay,( Rookie mistake). I went back and checked the power to the pump. So glad ya'll suggested the Ads pump. No Expensive parts needed. Thank you for your help.
  1. Cannot Communicate with ABS Module after Repair
    By TheAvenger in forum Diagnostic Software
    Last Post: 12-15-2018, 10:54 AM
  2. Removed ABS Module for Repair
    By humanite in forum 1995 - 2001 (E38)
    Last Post: 08-05-2013, 11:09 AM
  3. '97 Z3 ABS, ACS, and check engine lights. need help!
    By mmckiness91 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-18-2011, 09:04 PM
  4. ABS module not repairable
    By 00740il in forum 1995 - 2001 (E38)
    Last Post: 10-26-2010, 12:28 PM
  5. ABS Module Removal/Repair/Diagnostics
    By jamesdc4 in forum 1996 - 2003 (E39)
    Last Post: 12-28-2009, 02:21 PM
