Results 1 to 5 of 5
Thread: Starting Problems
    May 2017
    Lebanon, Indiana
    1988 Bmw 325is
    Starting Problems
    So I have a 1988 325is and i have had a problem where it wont start it just cranks and cranks, it has fuel, spark, air, the essentials. However, when the car doesn't start i will often just pull start it with another vehicle, it will start right up when it is pulled started, I've done a lot of research and thought it was my crank position sensor, soon after replacing it the same thing happened again, after that i bought all new spark plugs and spark plug wires and got a new distributor but that was not a solution to the problem, i have a few theories of what it could be like low pressure in the fuel system. i am hoping one of you guys could hopefully give me some advice. Thanks for reading and i hope to hear your response!
    Oct 2003
    Seattle
    99 M3
    Have you measured fuel pressure and injector output volume?
    Battery health?
    May 2017
    Maryland
    1986 BMW 325e
    Quote Originally Posted by bigbagman View Post
    check the battery
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    if it cranks and cranks, then probably not the battery.
    I would think fuel pressure also but you need a gauge to check
    No e30s again.
    May 2017
    Lebanon, Indiana
    1988 Bmw 325is
    i have put a new battery in it about 4 months ago so i don't think that's the problem
  1. 325 gurus - need help - starting problem
    By scribbleman in forum 1991 - 1999 (E36)
    Last Post: 10-04-2002, 03:02 PM
  2. Starting problem
    By heatmizr in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2002, 04:59 PM
  3. Starting Problem
    By JoeCinVA in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-13-2002, 08:51 PM
  4. Cold Start Problem
    By MAB Badgerbimmer in forum 2001 - 2006 M3 (E46)
    Last Post: 06-16-2002, 10:41 AM
  5. Cold Start Problem
    By SmokinU in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-17-2002, 12:59 AM
