Results 1 to 14 of 14
Thread: Steering wheel shimmy on braking - before and after full brake replacement.
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    I replaced all four corners with Bosch rotors / ate pads, bled & purged system and still have a little bit of a steering wheel shake on braking. All new Michelin Defender tires, bottlecaps torqued with new bolts. PO replaced control arms and possibly other components about 30k miles ago. Where would I go hunting for this shimmy?
    Oct 2003
    Seattle
    99 M3
    Tie Rods, wheel bearings.
    Joliet,IL
    87 325is 96 GMC Suburban
    What size tires did you put on it
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by msservices View Post
    …and what brand of wheels? Hub centric?
    Jul 2013
    CT
    Michelin Defender T+H 185-65-14 on factory bottlecaps.
    Thanks for the tips on tie rod and f wheel bearings. Since I get occasional vibration at speed in addition to braking wheel bearings seem a likely culprit.
    Joliet,IL
    I would replace the wheel bearings and tie rod assembly’s, but struts can allow slop and do weird things also. Make sure the control arm bushings are new and installed correctly. I think I would go with the solid rubber ones if I had to do it again. Also I have found e30s seem to disagree with certain tire brand/sizes and even though I run Michelin on all my other vehicles I would not run that size on an e30 for the reason you are posting.
    Oct 2003
    Seattle
    99 M3
    Are you referring to E36M3 FLCABs?
    If so, p/n 31129069035 for the centered 1996+M3 FLCABs
    And p/n 31129064875 for the (recommended) offset 1995M3 FLCABs.
    Jul 2013
    CT
    PO replaced control arms and bushings at 85k, i'm at 116k now. All I know about the parts he used is attached photo...
    Do not believe he replaced tie rods, I can do that and the wheel bearings, doesn't seem to bad a job.
    Thinking behind these is added durability, with I presume some added stiffness and therefore noise/vibration/harshness?
    Quote Originally Posted by bluptgm3 View Post
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by somecarguy View Post
    Yes, the centered 1996+M3 FLCABushings do add some ‘road feel’ without adding much NVH.
    I would look at the Tie Rods for some slop.
    What tires are you running? Do they balance well/easily? Any chance you have a bent wheel?
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    off topic: I used the race control arm kit from garagistic instead of m3 control arm bushings last time. the ones that look like those treehouse racing ones, really small and solid. man, I loved those. no play at all. and I didn't feel anything different than before. everything else was stock but those. totally fixed all my steering issues in the 86 325 because I replaced tie rods, control arm bushings, and control arms
    these ones
    https://store.garagistic.com/bmw-per...Arms-Treehouse
    No e30s again.
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    I replaced my right tie rod, that fixed my wheel shimmy. Cheap and fairly easy except for the funky lock washer BMW uses on the right end of the tie rod. You should be able to check wheel bearing by jacking the tire up, see if any excess play, then spin to see if smooth. As stated above, front struts have a big effect on an e30's handling
    Jul 2013
    CT
    Thanks all. Most of these parts seem affordable and not too difficult to replace, I will address them soon.
    The exception to that rule is the strut. When you all mention strut wear, which component are you refering to? Presumably not the insert? The rubber at the top?
    Joliet,IL
    The cartridge, or insert, and the mount, which has a bearing in it and rubber as well
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    The front strut usually consists of just replacing the shock. Borrow a coil compressor from the auto parts store. Remove the strut, compress the spring, remove the shock and it's fittings. Check top mount. Then intall new shock by doing reverse.
    $53ea Monroe from Oreilly's
  1. Bad steering wheel shimmy braking!
    By ianweber in forum 1996 - 2003 (E39)
    Last Post: 08-27-2010, 07:30 PM
  2. Steering wheel Shimmy and Clunk sound when braking.
    By clarkerussell in forum 1991 - 1999 (E36)
    Last Post: 05-01-2008, 10:02 AM
  3. Steering wheel "shimmy" while braking
    By EnvyM3 in forum 1999 - 2006 (E46)
    Last Post: 08-14-2006, 03:49 PM
  4. Steering Wheel Shimmy Under Braking at 55mph
    By JAlfredPrufrock in forum 1996 - 2003 (E39)
    Last Post: 04-14-2005, 08:53 AM
  5. steering wheel shimmy left-to-right when braking...
    By Bavarian328 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-19-2003, 01:01 AM
