Results 1 to 16 of 16
Thread: Another part that's NLA
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    I just checked to see if I could get a door striker for my roadster to solve a alarm falsing issue and dome lite problem. I checked FCP and ECS... no go. I called the dealer.. none in US or Germany. I hope they make some more but the dealer wasn't sure they would be. Looks like it's time for a DIY repair
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Nathan in Denver
    Aug 2012
    Kansas
    Thanks Nathan I was starting to get worried. Found them on getbmwparts too.
    Redding Calif
    1999 Z3 2.5L 5sp
    eBay has been a major source of parts for me also ;-)
    Aug 2012
    Kansas
    Well it's strike three. I just got a email from the eBay seller canceling the order due to no stock and no known date of availability. The search continues.
    Aug 2015
    Denver, CO
    Quote Originally Posted by z3forlife View Post
    I do have a spare pair (used) that I grabbed for a rainy day and would be willing to part with one of them. I could dig it out after the Xmas holiday. You can have the passenger's side that I'd imagine has quite a bit less use on it. Shoot me a text. I'll do Black Friday pricing.
    Nathan in Denver
    Aug 2012
    Kansas
    This will be the next part to horde since they often fail especially the driver side. Good thing they're universal
    Aug 2015
    Denver, CO
    Indeed. I only knew which side was used on the passenger's side as the seller marked them.
    Nathan in Denver
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    If someone had a way to add a little plastic or something even more resistant to wear to the little nub that gets pushed in to make the lights go out, we could continue to use what we already have. I've put some clear tubing on the bar to replace the rubber that wore out, but the tape on the little nub just doesn't stay on long enough, especially in the hot weather when the adhesive gets soft.
    I bought a replacement at least a year ago so I have a part to make the driver's door work but would hope to be able to fix the worn one if possible.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
    We are entering the dark times as far as parts availability goes...
    PRICE CUT on ALL FABRICS
    Sep 2002
    TX
    01 Z3 3.0i
    For what its worth, I was told they are not NLA just back ordered with a supply chain issue, BMW has 650 on back order with the manufacture so atleast from I was told, They will be getting more in just a matter of when.That being said. It is getting more common for parts going NLA for these cars which I am a bit surprised on some items like the reflectors for the rear of the roadster.
    Sep 2002
    TX
    01 Z3 3.0i
    I grabbed a E36 sedan one and they are exactly the same other then, The E36 has a longer wire without the grommet, However the plug is the same and the grommet can easily be moved over, If you are in a pinch and want a brand new one
    S54 Roady, LS1 & LS2 E36
    On my E36 325i driver door latch light switch nub I cleaned it well with alcohol and laid a small bead of hot glue on it. I had my doubts that it would last, at all. 2000 miles later and it's still on there and working flawless. Honestly was surprised and decided that I'll just fix it as needed with hot glue.
    Aug 2012
    Kansas
    My local dealer said 600+ are due in soon.
    Aug 2012
    Kansas
    Just checked again and still on back order. My dealer searched and still over 600 pending availability. Now you better take a seat cause the “list” price for one when available is $206. I about fainted. I went home got out my torx sockets and successfully adjusted the striker so no gouging at this time.
    Apr 2006
    Sacramento, California
    2000 M Coupe 1995 M3
    The only way I got a hold of a door striker was to buy used from eBay seller. (Look for oem bmw parts dismantler).
    1995 Dakar M3​-Z3 Steering Rack
    2000 Dakar M Coupe-Bilstein Shocks, H&R springs, upgraded sway bars/bushings, and rear shock mounts
    2000 Dakar M Roadster-Sold
    2005 Alpine White/Imola Red M3 Vert-Sold
    2002 Dakar Yellow Z3 Coupe-Sold
  1. Another part gone NLA.......
    By 8Tech in forum 8 Series (E31)
    Last Post: 02-25-2014, 04:57 PM
  2. BSW needs another Part Time/Full Time Help - Please See inside
    By Halston Pitman in forum Georgia sponsored by Harrison Motorsports
    Last Post: 03-15-2007, 10:35 AM
  3. Got another parts car
    By evoe46m3 in forum 1983 - 1991 (E30)
    Last Post: 05-02-2006, 02:08 PM
  4. Another part number... vanos control solenoid?
    By M3Alpine99 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-23-2005, 06:02 PM
  5. another part # request
    By nateb in forum 1983 - 1991 (E30)
    Last Post: 08-05-2003, 05:28 PM
