Page 2 of 7 FirstFirst 1234567 LastLast
Results 26 to 50 of 163
Thread: Build log: LS2 330i
  1. #26
    Mar 2011
    PNW
    LS E46
    I’ve sure never heard of anything besides those two options. I suppose if you can tig really good...
    Cupronickel line bends super easy, doesn’t corrode and looks really pretty - though it’s kind of spendy.
  2. #27
    fairfax,va, usa
    2 E30s and a maxima
    Stupid minor update. I got the gas pedal in. The DBW pedal is so tall that hits the steering shaft. Moving it to the left was hard because there's a bunch of wiring brackets in the way that I wound up cutting out. I bent the pedal over a little until I broke my wooden bench. The pedal isn't in the most ideal spot but it works for now. Pedal adapter is 100% bolt in with no chassis welding so that's nice.
    I pick up the rest of my parts on the 16th so I'm really just killing time until I get everything in. Hopefully the weekend after I can get the motor in.
  3. #28
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I bent the F out of my DBW pedal to get it in and in a good position. I actually cut it twice and bent it in to like a Z and then welded it.
  4. #29
    fairfax,va, usa
    2 E30s and a maxima
    Yea I might cut and weld it one day. Well see how much I hate it.
    Sent from my SAMSUNG-SM-G930A using Tapatalk
  5. #30
    Mar 2011
    PNW
    LS E46
    The steel ones supposedly have a very similar sensor to BMW’s DBW pedal and is close enough in values to work. Someone on here did it with their E39 if you look around.
  6. #31
    fairfax,va, usa
    2 E30s and a maxima
    I saw. I might do that one day. That's why I made this one bolt in.
  7. #32
    fairfax,va, usa
    2 E30s and a maxima
    I got my parts in. Been working with Committed Service Brand (does Austin Meek's and Taylor Hull's cars). The moroso pan doesn't come with bolts or gasket so, crap, I have to order that. On top of that, I can't find the right bolt for the pickup tube. Anyone know if I can just find a bolt in my junk pile and locktite it in and be fine?
    Rear suspension is mostly in. But of course the M3 diff has a broken bolt I have to extract. I also ordered a clutch masters fx400 8 puck clutch so I'm excited about that. Hopefully I can get the motor in soon.
  8. #33
    Mar 2011
    PNW
    LS E46
    Pickup tube bolt can be anything. Oil pan bolts are probably gonna need to be ordered as a set tho, there are 2 really long ones at the trans.
  9. #34
    fairfax,va, usa
    2 E30s and a maxima
    I ordered the ARP oil pan bolt set for gen3/4. I think that's right. LS engines have too many combinations. It gets so confusing >_<
    I also completely botched the bolt extraction out of the diff. Hopefully I can salvage it by buying more tools. Remember kids. Center punch then drill in the CENTER.
  10. #35
    Apr 2017
    NJ, USA
    '07 335I 6MT, '01 330i
    I never actually though of doing a little punch in the center..... I'm an idiot.
    Keep it simple: half gutted '01 330i, welded diff, BC coils, SLR Super kit
  11. #36
    fairfax,va, usa
    2 E30s and a maxima
    Yea I have a center punch for it too. I just screwed it up
  12. #37
    Mar 2011
    PNW
    LS E46
    They’re red-loctited in place, you need to heat them to ~500F to break the bond.
  13. #38
    fairfax,va, usa
    2 E30s and a maxima
    Are they? This is the big bolt that mounts the side of the diff to the subframe. I dont get the design. It's so terrible.
  14. #39
    Mar 2011
    PNW
    LS E46
    Oh I thought you meant inside. Never mind.
  15. #40
    fairfax,va, usa
    2 E30s and a maxima
    So after a lot of cursing and an ER trip to get a stitch put in my finger, this is what I pulled out. It actually punched a hole in the diff somehow. All the threads are jacked so I'm gonna drill it out and helicoil it. I thought people treated M3s well? This looks like someone ugga duggaed for a solid minute straight. Wow what a pain. Literally.
  16. #41
    Mar 2011
    PNW
    LS E46
    Lots of stupidity in the world. Too bad there isn’t a cure.
  17. #42
    fairfax,va, usa
    2 E30s and a maxima
    I mean I'm pretty stupid for knuckle punching a cutoff wheel with only latex gloves on lol.
  18. #43
    Apr 2016
    Detroit, MI
    1997 328i, 89 325ix
    Quote Originally Posted by protomor View Post
    A few weeks ago my finger tip met with a cutoff wheel and it was no fun. Strangely it didn't really bleed despite cutting into the nailbed pretty well, and it healed up really nicely lmao
  19. #44
    fairfax,va, usa
    2 E30s and a maxima
    Yea something about the grinder makes it not bleed as much. Altho I'm still cleaning blood spatter all over my house and garage.
  20. #45
    fairfax,va, usa
    2 E30s and a maxima
    Hopefully this thing goes in today. Wish me luck.
  21. #46
    fairfax,va, usa
    2 E30s and a maxima
    Well the rear sump made things hard. Had to basically undo the subframe and steering shaft. Oh well. It's in now. Hopefully it doesnt have to come out.
  22. #47
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    you put in in without headers on? Mine the headers physically can't fit in or out with the engine in, they have to go with it.
  23. #48
    fairfax,va, usa
    2 E30s and a maxima
    Yea they fit in with the motor in. But uh, they arent complete headers so we'll see. I got a lot ahead of me. 3 inch down pipes too lol.
  24. #49
    fairfax,va, usa
    2 E30s and a maxima
    I take that back. I can barely get the passenger's header in but the driver's side 100% won't go in. i also think I installed one side's mount upside down.
    Man the driver's side is tight. I have no idea where to mount the fuel pressure regulator. I also think the header is gonna be super close to the ABS module. Gonna have to heat shield the brake lines on that side too.
  25. #50
    Irwin, Pa
    97 M3, 12 135i
    Next time pull the intake manifold. Takes 5 minutes and makes it about 50x easier to clear the firewall when putting engine and trans in together as a unit.
  1. E36 M3 Track Car Build Log
    By MRichmond in forum Track Car Builds
    Last Post: 03-09-2014, 06:49 PM
  2. M Coupe Stereo Build Log
    By Mister X in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-03-2008, 02:18 AM
  3. M Coupe Stereo Build Log
    By Mister X in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-01-2008, 07:23 PM
  4. Build Log: Myster the Vert & ED Disfunction
    By Myster in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-20-2006, 02:16 AM
