Page 3 of 3 FirstFirst 123
Results 51 to 67 of 67
Thread: Build log: LS2 330i
  1. #51
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Put the FPR under the car where the stock e46 was
  2. #52
    fairfax,va, usa
    2 E30s and a maxima
    It's a combo FPR and gauge. I kinda want it some place I can see. I'm thinking near the fuse box but man header clearance with the fuel lines are TIGHT. How's yours run?
    Status: HG repair. 488wtq though!
  3. #53
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I have the corvette fpr under the car in the stock e46 location and an in-line gauge right before the rail
  4. #54
    Mar 2011
    PNW
    LS E46
    What do you need a gauge for? Just get the corvette fpr, put it in the stock location and call it a day. You’re not even boosted, you don’t need a gauge, just a quality pump.
  5. #55
    fairfax,va, usa
    2 E30s and a maxima
    It's a combo gauge/fpr/returnless regulator/ adjustable regulator. I have it, it's $0, I just want to mount it somewhere and be done with it.
  6. #56
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Quote Originally Posted by Liquidity View Post
    Gauge is always good to have, especially with the hit or miss of the corvette FPRs, I've gotten 3 bad ones out of the box that were easy to see instantly due to having the gauge.
  7. #57
    fairfax,va, usa
    2 E30s and a maxima
    Well that's some good news. Lines up like butter.
    Sent from my SM-G975U using Tapatalk
  8. #58
    Mar 2011
    PNW
    LS E46
    Wow that shifter location is spot on perfect. Why did everyone tell me to get the f-body tail housing? Well looks like I’m in for some work right off the bat. Fml.
  9. #59
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I have the F body tailhousing in my car and the shifter fits perfectly through the factory hole, no trimming needed. No idea how the GTO shifter here fit so well.
  10. #60
    fairfax,va, usa
    2 E30s and a maxima
    I have an MGW shifter which is offset. So it's actually sitting farther forward (I think forward) than where the shifter actually sits. The shifter bit rides up against the factory hole for the shifter.
  11. #61
    fairfax,va, usa
    2 E30s and a maxima
    Well here's today's issue. I tried making heat shields but there just isn't enough space. I guess I'll header wrap both the headers and the brake lines and see how things go.
  12. #62
    DeWitt, Michigan
    '97 540i/6, '97 328i
    The stuff I have used on my super tight downpipe fitups works fantastically. It's this stuff. A little pricey, but awesome. They have it in quarter inch and half inch thicknesses, and various lengths/widths.
  13. #63
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    ceramic coat, then you don't get itchy all day after you work on your car
  14. #64
    fairfax,va, usa
    2 E30s and a maxima
    But I like getting itchy. I also dont know anyone local who does ceramic coating.
  15. #65
    DeWitt, Michigan
    If you use that stuff I linked, you only get a little itchy when you install it, and then not again. All of the itchy is contained inside the dimpled aluminum outer layer.
  16. #66
    Mar 2011
    PNW
    LS E46
    As long as the heat shields don’t physically touch the headers or brake lines, they’ll do their job, doesn’t matter how close they are. It’s radiant heat you’re protecting from: think stepping into the shade because the sun is beating down on you too hard.
  17. #67
    fairfax,va, usa
    2 E30s and a maxima
    I couldn't fit a heat shield in between them without them touching. Otherwise I would have.
  1. E36 M3 Track Car Build Log
    By MRichmond in forum Track Car Builds
    Last Post: 03-09-2014, 05:49 PM
  2. M Coupe Stereo Build Log
    By Mister X in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-03-2008, 01:18 AM
  3. M Coupe Stereo Build Log
    By Mister X in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-01-2008, 06:23 PM
  4. Build Log: Myster the Vert & ED Disfunction
    By Myster in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-20-2006, 01:16 AM
