Hey!
I own a BMW 316i 1.6 17xx cc Automatic from 2002.
Recently I have a problem where I have to refill my engine oil almost every 3-4 days. When looking at the oil dipstick, I saw a very small amount of yellow / white residue at the tip of my oil dipstick. (thought it was a head gasket problem but that was not the case).
My engine also makes a growling noise after several minutes (when the engine is warmed up). This only happens between 2000-3000 rpm when accelerating (SEE VIDEOS with sound)
- Coolant always remained the same (no leaks)
- No trace of engine oil leaks (ground of garage, ..)
- during a trip of 1 hour - no overheat symptoms (temperature always stayed in the middle)
- No fault codes
Someone an idea what caused this ??
Beneath are the links to the videos
Replace #1,#3 along with clamps if needed:https://www.etkbmw.com/bmw/EN/search...E6/ECE/11_1514
