Bavarian Soundwerks
Results 1 to 3 of 3
Thread: BMW F13 - no sound
    Dec 2018
    UK
    2015 BMW M6
    BMW F13 - no sound
    Hi everyone
    This is my first post so please be gentle! I have a three year old M6 with just under 7000 miles showing. The sound system works fine and you can change between all the different sources but there is no sound coming out of the speakers. There is also no sound from the reversing sensors. Is there a simple fix for this or is it more than likely to be the amplifier? It's just out of warranty by a few weeks :-(
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step is to determine which fuse(s) power th amp. Then, you need to entice each fuse and check it with an ohm meter. Alternatively, you can, with the head unit powered up, check for the voltage across each fuse. There should be 0VDC across the fuse(s).
    If the fuse(s) is ok, I recommend you take the car to a reputable indie shop that specializes in bimmers. The electronix in these cars are highly integrated. As a result, the reputable indie shop should have all the software needed to scan the car, including the audio system.
    Sep 2008
    West London/Heathrow - UK
    03 530dT - Ex Police Car
    Hi
    As per Marco's post above. Also, where in the UK are you? there's a good few reputable, knowledgable and experienced specialists who should be quickly be able to determine the issue/fault etc. I'll point you to some that are closer'ish to you.
    Cheers, Dennis!
  1. Bmw Turbo Charged Sound???
    By bigm77 in forum 1996 - 2003 (E39)
    Last Post: 09-24-2006, 08:43 PM
  2. BMW Distinct Engine Sound?
    By Geeforce in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-03-2006, 04:51 PM
  3. 2 BMW CCA Puget Sound Region Club Drives
    By RedmondRocket in forum Pacific Northwest - US
    Last Post: 08-22-2005, 09:53 AM
  4. M3 Pics from BMW CCA Puget Sound Chapter Meeting
    By daihard in forum 2001 - 2006 M3 (E46)
    Last Post: 03-31-2004, 10:21 AM
  5. BMW CCA Puget Sound All Members Meeting
    By jmillet in forum Pacific Northwest - US
    Last Post: 02-09-2004, 02:26 PM
