Results 1 to 9 of 9
Thread: Ista/d + bmw x5 e70 2008
    Jan 2014
    Ashgabat, TURKMENISTAN
    BMW X5 E53 1999
    Hi All,
    So far I have tried 4 different versions of ISTA/D. Non of it has VANOS timing and leak tests. Only camshaft position tests.
    Is there a tick to enable VANOS tests? BTW, I don't have an I-COM just regular USB OBD cable.
    This is the version I have at the moment .
    Regards,
    Oleg
    Jul 2004
    Houston, TX
    36 Cylinders
    ABL is usually grayed out until you actually connect to vehicle and perform a complete identification. If you search it without connection to car, it will be gray.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jan 2014
    BMW X5 E53 1999
    This what I have done from the very beginning . No sign of VANOS tests even after complete identification.
    Text search gives only two ABLs as well. Also no 'dms' tests
    Actually I'm looking for similar options in 'Function Structure' but no luck.
    BTW, my engine is N52K 3.0si if it make sense.
    Jul 2004
    Houston, TX
    36 Cylinders
    Ah ok.
    I use 4.06 and 4.09 and have not ran into this issue, yet.
    I haven't experimented much with the N52.
    -Abel
    Jan 2014
    BMW X5 E53 1999
    Have you tried this with I-Com connected or simple USB cable ? BTW, I have tried the above versions too. All the same.
    Jan 2014
    BMW X5 E53 1999
    Ok, I have simulated with N55 engine and apparently it gives separate tests for camshaft and VANOS solenoids. I believe it could be N52 engine issue. Looks like ISTA can't run VANOS tests on N52
    Sep 2010
    Estonia
    2000 BMW 740i
    Your i-level is too low to perform VANOS tests. Update E70 (ista/p or winkfp) and all be fine.
    Jan 2014
    BMW X5 E53 1999
    You mean I would need to update ECU with newer F/W ?
    Sep 2010
    Estonia
    2000 BMW 740i
    Yes.
  1. E70 BMW X5 E70 Rear Seat DVD Entertainment System OEM Kit New
    By jtharmon in forum Car Audio & Electronics
    Last Post: 01-17-2018, 05:50 PM
  2. E70 Share BMW X5 E70 Car accessory stainless steel scuff plate door sill plate LED light
    By mycareye in forum Exterior Lighting & Body Parts
    Last Post: 06-22-2015, 10:48 AM
  3. X5 E70 2008 Bluetooth Blackberry Pairing Problem
    By Keith K in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 12-01-2011, 11:32 PM
  4. E9x Chip Express BMW 335d Diesel Tuning Box for BMW 335d and BMW X5 E70 35d (US Spec)
    By myee123 in forum Engines, Performance Parts & Software
    Last Post: 08-27-2011, 12:02 PM
  5. BMW X5 E70 ecu pinpoint
    By sinerja in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-20-2011, 05:45 PM
