Results 1 to 6 of 6
Thread: B pillar cover interior . . .
    Apr 2012
    ny
    1998 328i
    i have 4 door 328i 1998 . my B pillar makes squeaky noise when i go over bumps.
    When i partially remove the top of theb pillar platic cover it seems there was a tab there but it broke off i think.
    But it seems this missing piece goes into just a square hole in the car trim..
    Is there a clip this broken tab goes into ?
    i looked at real OEM but didnt see anything, but those diagrams are tricky.
    thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    #2 metal clip 51437194187 http://www.realoem.com/bmw/enUS/show...diagId=51_2039
    probably it disappeared inside the B=pillar. When I did my headliner and A,B, C pillars I ordered some of them as spare, the easily get lost. The tab of course you also have to remake, I used a glass fibre mat repair kit with resin, re-shaped it and works well, stronger than the old plastic. Did that already before on my E32
    Mar 2001
    houston
    '94 325i,'08 civic
    have same problem..
    Quote Originally Posted by enf1945 View Post
    thanks
    yes, same here. upper plastic clip on panel broken. my plan is to use 2 sided tape where will do most good to stop plastic tapping at low speeds. until then i place flexible material between pillar and passen seat to quiet.
    Apr 2012
    ny
    1998 328i
    thanks,
    What holds the clip in ?
    All i see on the body is a square hole about 3/4 inch
    Jan 2005
    Japan
    There is a square hole in the b-pillar, where you insert the clip
    Trim Retaining Clip For BMW 51437194187
    Apr 2012
    ny
    1998 328i
    thanks for the help. Really great people here . .
    I placed foam insulation thats used for windows (sticky on one side) a little below
    where the broken tab is. Maybe 2 inches long.
    I also put a little white Zinc grease along the edge of the Pillar cover along the sides / edges above
    the seat belt point.
    where it meets the rubber.
    Wiped off excess.
    And noise is gone !!!
    I think alot of that squeak is the rubbing of the rubber against the cover. . But both the grease and insulation buffer did it.
  1. wtb: drivers side e36 2dr interior A pillar cover
    By BJO in forum BMW Parts Wanted
    Last Post: 11-18-2009, 05:34 PM
  2. Interior Pillar Covers
    By ramboz in forum 1999 - 2006 (E46)
    Last Post: 11-27-2008, 12:07 AM
  3. E39 FS: E39 M5 Interior A-Pillar covers in black - Excellent shape
    By DPRE187 in forum Exterior Lighting & Body Parts
    Last Post: 10-22-2008, 01:51 AM
  4. Looking for black interior pillar covering material
    By BlackSapphire in forum 1996 - 2003 (E39)
    Last Post: 09-14-2008, 09:36 PM
  5. looking for e 36 interior window pillar covers
    By nacnac250z in forum BMW Parts Wanted
    Last Post: 04-10-2008, 10:29 PM
