Results 1 to 6 of 6
Thread: E36 320i 1997
    Dec 2018
    Romania
    1997 BMW E36 320i
    E36 320i 1997
    Hello, my e36 just suddenly stopped starting anymore. It cranks forever but won't start, the fuel pump is working, it has spark, crankshaft position sensor is new, camshaft position sensor got changed about 6 months ago, vanos unit is jammed since maybe 1 year but sometimes it kicks in and sometimes doesn't. It does sound like the compression is low, it has 4 bars on all cylinders but something like this can't happen like suddenly ....it has to give me some signs before it will just die because of compression so i do think it's related to other things my car is not starting. There is no water in oil or oil in water however you wanna put it, it doesn't overheat so the head gasket should be fine.
    on inpa it throws the o2 sensors error, on both of them and that's all
    One day i just started the car and moved it 10 cm and let it for about 30 min and when i tried to start it , it started but with misfires, poor air/fuel mixture and after that it never started again.
    My question is could it be the camshaft position sensor dead again and not throwing any error code ?
    Oct 2003
    Seattle
    99 M3
    E36 320i 1997
    What are the O2 sensor codes and how many miles on them?
    Any chance you have a large vaccine leak? What condition is the rubber intake boot, any cracking?
    Dec 2018
    Romania
    1997 BMW E36 320i
    the o2 sensors don't have more than 10k miles and the intake boot is new
    Jun 2010
    NY
    1997 328i
    You have to test fuel pressure.
    Oct 2016
    Tenerife, Spain
    1997 BMW E36 323i
    +1 on what Eric said. Check fuel pressure.
    Symptoms point in the direction of bad fuel pump, bad fuel pressure regulator (they can die both ways: giving too high or too low pressure), or clogged fuel filter (less probable, because symptoms first arise at high loads, not at idle).
    Also, recheck cylinder compression.. Should be around 11 bar. Your meter is probably bad (is it a cheap ebay one, then throw it away; but first retest with a good quality one that cost like 100 euro; I bought a digital one and it's extremely precise). If it's really 4 bar, you won't get the engine to start anymore, or, if you do, it wil run very, very poorly. Your analysis is correct I think: the chances of all cylinders going to 4 bar all of a sudden, are virtually zero.
    1997 E36 BMW 323i
    (European) 275k km (171k miles), with following small mods:
    Dec 2018
    Romania
    1997 BMW E36 320i
    ok, i did a recheck on cylinder compression, it's around 11-13 bar. I believe it is flooded, i will give it a try tomorrow because right now i just killed the battery so i will put it to recharge.
  1. Replies: 2
    Last Post: 09-28-2016, 09:36 AM
  2. 1997 e36 320i no power fells choked
    By e36320ii in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-27-2014, 02:31 AM
  3. E36 FS: e36 m3 1997 Bay Area
    By SmokedM3 in forum 3 series & Z Series
    Last Post: 12-29-2011, 11:02 PM
  4. E36 FS: e36 m3 1997 Bay Area
    Last Post: 12-28-2011, 01:34 AM
  5. 1997 E36 320i
    By Fraghat in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-13-2010, 04:05 AM
