Results 1 to 4 of 4
Thread: VAC S54 ATI Damper installation question
    Apr 2009
    Richmond, MA
    I'm installing a VAC/ATI damper on an S54, I measured the thickness of the portion where the four securing bolts go through the damper and it is thicker than the stock damper. The stock damper uses a little steel washer/plate with 4 holes in it however (if I include this washer on the stock damper, they are both about the same thickness). I'm trying to determine if I use the washer on the VAC/ATI damper?, and if so would I need longer bolts to compensate?, or is there enough thread in the OEM bolts to not be a problem? I assume the purpose of the plate is to provide a suitable hardness material for the bolt head with the stock damper, the VAC/ATI damper looks to be steel in this area so I would think it would not need the washer/plate. Nothing in the instructions about this. thanks
    Oct 2003
    Seattle
    99 M3
    Ya I’d be inclined to use new stock bolts and #7.
    http://www.realoem.com/bmw/enUS/show...diagId=11_2997
    Apr 2009
    Richmond, MA
    I have new bolts, and with part #7, it shortens the length of the thread engagement by the thickness of the washer (1/8-3/16")...
    Quote Originally Posted by bluptgm3 View Post
    Jan 2003
    Free America AZ
    German ones
    Was this ever resolved? I'm having fitment issues with my new ATI S54 damper as well.
    Dave
    '18 RAM 2500 Laramie Cummins
    '15 Pure White VW Touareg TDI
    ///'95 Avus M3 S54B32 Race car -- 2022 ProAutoSports PS1 Champion
    ///'72 Chamonix 2002 (Restoration project)
  1. FS: New S54 VAC ATI Damper
    By AGRESIVE in forum Engines, Performance Parts & Software
    Last Post: 06-27-2018, 12:08 AM
  2. ATI Damper Install Issues...
    By litemup in forum Forced Induction
    Last Post: 02-23-2017, 07:35 AM
  3. WTB VAC Motorsport ATI Damper for S54
    By Shainz in forum BMW Parts Wanted
    Last Post: 02-15-2016, 04:29 PM
  4. VAC sub belt bar, instal question?
    By ///M3 CRAZY in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-01-2012, 06:16 PM
  5. S54 Pan/Pump installed...question about oil pressure.
    By vinnymac in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-12-2009, 05:26 PM
