Results 1 to 6 of 6
Thread: M50 Turbo MPG gauge questions with MSxx
    Feb 2016
    Portugal
    1993 e36 320i;1990 525i
    Post M50 Turbo MPG gauge questions with MSxx
    Hello guys
    So what im asking about is if i can make the MPG gauge work with megasquirt ECU. I know that the mpg gauge will only work with factory ecu with the pulse width from injectors that the ecu sends, but i wanted to get it working with the megasquirt... Is it possible ?
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Quote Originally Posted by rezhak View Post
    Hello guys
    My plug and play MS3 should do it natively when its used on a normal OBD1 vehicle. Mine is OBD2 and the cluster uses 2 wires instead of one so it doesn't work for my setup.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Dec 2018
    Prague, Czech Republic
    1998 318ti
    Hello guys
    Yes, if you have some spare PWM output, it is possible.
    Feb 2016
    Portugal
    Quote Originally Posted by dodo4 View Post
    Im using a ms2 and im obd1 how can i make it work? i think i have it since i didnt mess around with the outputs and inputs yet.
    Dec 2018
    1998 318ti
    You can found necessary info here (delete extra spaces):
    http://ww w.msext ra.com/forums/viewtopic.php?f=131&t=59516
    Basically you have to have working speed input to gauge cluster from rear diff and then just add pwm signal simulating injector pulse. For this you can use spare pwm output of your ECU (depends on your specific install)
    Feb 2016
    Portugal
    Thats very helpfull thank you very much!
  1. nonvanos m50 turbo engin build question (noob)
    By h2oplaydamian in forum Forced Induction
    Last Post: 03-07-2008, 06:38 PM
  2. m50 turbo questions
    By euro trash in forum Forced Induction
    Last Post: 11-06-2007, 04:28 PM
  3. Some very basic m50 turbo questions....
    By brew in forum Forced Induction
    Last Post: 10-29-2007, 05:55 PM
  4. Couple Questions? m50 (turbo)
    By mrt0mjones in forum Forced Induction
    Last Post: 08-23-2007, 09:08 AM
  5. Non-Vanos M50 Turbo Questions
    By bimmer328ci in forum Forced Induction
    Last Post: 04-04-2007, 07:55 PM
