Results 1 to 2 of 2
Thread: 650i turbo cooling lines replacement guidance (shop manual for 2012 would help)
    Dec 2018
    Scottsdale, Arizona
    2012 BMW 650i Coupe
    After recent recall for auxillary cooling pump replacement the tech noted that the cooling lines to the turbos are leaking. Discussion with BMW engineer onsite said this is a common problem due to the heat in the V of the motor. He also said they have started insulating those lines when replaced. I'd like to tackle this and a few other items but not without some guidance. The BMW engineer here said their shop as well as other independent shops use expensive software (electronic shop manual). An owner like myself could not justify that expense however I would like to maintain my own vehicle to the extent possible so that I know the condition. I will and have taken it to the pros when it is over my head.
    Does anyone have a recommendation for this issue as well as other maintenance issues that reasonably competent owner can tackle? 2012 650i 55k miles, love it.
    Thanks, Steve
    Jan 2016
    Ca
    2001 525it
    You buy all four lines the take those apart and use the rubber hoses on yiur metal lines it's the rubber hoses that leak
  1. Turbo cooling lines with Euro Expansion Tank
    By CharlesHarris12 in forum Forced Induction
    Last Post: 07-16-2018, 09:17 AM
  2. Turbo cooling lines with Euro Expansion Tank
    By Mr Estoril in forum Forced Induction
    Last Post: 08-13-2017, 07:21 PM
  3. e34 540i transmission cooling lines replacement
    By Waitedog in forum 1988 - 1996 (E34)
    Last Post: 06-17-2015, 11:06 PM
  4. Final drive oil cooling line, replacement.
    By fstenb in forum 8 Series (E31)
    Last Post: 05-28-2014, 04:30 AM
  5. auto transmission cooling line replacement
    By viali8 in forum 1983 - 1991 (E30)
    Last Post: 12-19-2010, 07:42 PM
