Results 1 to 7 of 7
Thread: Bosch 65 Amp Alternator Rebuild
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool Bosch 65 Amp Alternator Rebuild
    DSCI0378.JPG New 9-Diode RectifierDSCI0377.JPG New Rectifier Soldered to the StatorDSCI0379.JPGOld Slip Ring removed from rotor
    DSCI0382.JPG New Slip Ring installed and soldered in to Rotor windings.
    New SKF Bearings Front and Back--same as in this post..
    https://www.bimmerforums.com/forum/s...earing-Refresh
    Randy
    Nov 2007
    Cool
    DSCI0383.JPG Alternator Back side--new noise suppressor and Voltage Regulator DSCI0384.JPG Front SideDSCI0385.JPG Slip Rings 17mm ID x 28 mm OD with brushes---
    7 of them for less than the price of 3... .......Anyone doing this and needs a New Slip Ring--I have a few to sell. New Bushings are ordered and going to be installed to boot..
    New top and bottom Bushings installed-Polyurethane
    Ordered a new solid pulley for this one to cap off the alternator rebuild, pictures later, the pulley hole diameter matches the rotor shaft diameter, had a choice of bigger/smaller pulley.
    Randy
    Nov 2007
    Cool
    This 65A Alternator is done and ready for service, exchanged the BMW pulley from the 80 A alternator with this one, New Paint on EF as well.
    Randy
    Nov 2007
    Cool
    Just came back from Alternator test,, 1st test failed 11.1V output,, took out the new Aborn Voltage Regulator and put in new Huco Voltage Regulator-Made in Germany-all signs points to good--
    The machine testing the Alternator was coded for 1980 BMW E21 320i - Alternator
    Print out on Test Results:
    Lamp/Diode Trio: Passed
    Regulator Test: Passed
    Rectifier Test: Passed
    Battery Volts- Low 13.5,Actual -14.64, High 15.4
    Ripple Volts Low -0, Actual -.33, High 1.25
    Jump On Volts Low-0,Actual 1.51, High 8.00
    Jump Off Volts- 13.00 , Actual 14.61, High -0
    This alternator has tested good and will function properly in the vehicle.
    Just retested at place where 11.1V showed up with Huco VR
    Lamp / Diode Trio Passed
    Regulator Test Passed
    Rectifier Test Passed
    Rated Amps: 65
    Alternator is Good
    Randy
    Nov 2007
    Cool
    Update this is now installed and running very well,all signs point to good, The 100 A alternator is out to refresh its bearings and bushes and so forth.
    Randy
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Randy you always do great write ups pictures and explanations. Need a wiki or something with all of your posts and info. Keep up the good work!
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Nov 2007
    Cool
    Thanks, this one is running is good, Voltage is around 14.6 V, just tested it again, The rectifier plate with 9 diodes, I paid like $20.00 with free shipping.
    Randy
  1. How to rebuild Bosch water cooled alternator
    By RocketSurgeon in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-24-2016, 04:55 AM
  2. 1998 528i Bosch Alternator Rebuild for $30!
    By cnn in forum E39 Common Problems and DIY Fixes
    Last Post: 04-30-2014, 06:28 PM
  3. Bosch alternator rebuild
    By sigtwenty in forum 1995 - 2001 (E38)
    Last Post: 06-28-2013, 09:30 PM
  4. 1998 528i Bosch Alternator Rebuild for $30!
    By cnn in forum 1996 - 2003 (E39)
    Last Post: 06-03-2010, 08:38 PM
  5. Alternator rebuild kit?
    By jb325 in forum 1991 - 1999 (E36)
    Last Post: 08-16-2003, 02:15 PM
