Hey all, the time is coming up to start our roll cage. (We are building the coupe I wrecked a couple years ago) I am having some trying to find many pictures of coupe cages. We have the basic design figured out, but I would love to see some pictures of main hoop pads if anyone has any. I have seen a couple different setups so far, (plates on the floor and plates on the sill) but would really like to see some closeups if anyone has any. Even better if there are a couple shot of the process. Thanks in advance for any help.
Edited title, as this is really turning into the build thread, even though it started out as a question.
Never caged a Coupe, but it is my experience that you figure most of it out on the fly. Even our pre-cut kit made specifically for our Acura Integra Lemons car took weeks and weeks of fine tuning and fitting. We plated the main hoop to the floor, decided the floor was a bit too thin, and then sandwiched plates below between sub frame and frame rails. We did the same on the bottoms of the door hoops. I'm confident the cage would survive anything now. Another thing we did was hole saw where the verticals contacted the floor pan. Then we dropped the cage down through the holes, welded up the tops, jacked the entire cage back up as far as it would go, cut the bottoms off and slipped in the pads. This gave us maximum head room, and in some cases the fit was so tight we couldn't even get zip ties between to tie the foam. We also found that ratchet straps help align things before tacking.
Are you putting most of the interior trim back in or leaving it out? I'm guessing the floor pad arrangement would make an interior easier to go back in.
20170521_130342.jpg20170520_122134.jpg20170520_195200.jpg20170521_124227.jpg20170521_145022.jpg
Nathan in Denver
Definitely no interior. I have seen a couple that have the main hoop on the structure right over the sill, but I don’t know how you would be able to drop that to weld the tops of the tubing. That is my concern. But, if you do four bends on the main hoop and mount to the floor, you really only have good structure on one side of the box. There is not a lot of strength to the floor or the gas tank firewall.
Did you see these threads:
https://www.bimmerforums.com/forum/s...ight=roll+cage
When I built a cage for my 944 we welded the bottoms of the main hoop and the forward tubes last. We were able to slide things around enough to make enough room to weld the tops. I shouldn't way "we." I weld like a blind monkey, but the guy who was doing the welding for me (next door neighbor) was a bloody artist. He could produce fabulous welds in weird places with little room. I don't know enough about the coupe, but you may consider if you have such room and weld the bottoms last.
I have a friend who doesn't weld to the floor, but slots flat material for the tube to slide down onto and welds it in sheer (he boxes in the sides around the slot.
George Roffe
98 M Roadster
01 325iT
I opted for a bolt in back-half on this car http://spcarsplus.com/piwigo/index.php?/search/154
Oh man, this is some good stuff! Adker, I have been drooling over CMM3's build for a while now, but I had not seen the rally build. That is awesome! I will be reading all that and adding him to my stalking list. Geo31: That is kinda the plan, hoping with the sunroof and windows out, We will be able to find enough room to work. I am in the same boat though. Pretty good at wrenching, but when it comes to welding, um, I am a very functional clamp. Luckily, we have a pipefitter and a baddass fabricator on the team. Randy: I actually really like that design. It might help having tubing lower in the body for building the forward structure.
Thanks for all the replies! Definately a lot to think about in the next couple weeks.
Thought I would update this. We did not get the bender delivered yet. Hopefully in the next couple of days though, so we can get to work on it this weekend. We did however start with some reinforcements. Got both rear towers done, and one of the fronts. Also started getting the rear trunk floor/diff mount done. All plates, etc. are from Izzy's metal shop, or made by us.
48386336_369026847233970_5601775176720056320_n.jpg49057059_389158691829273_5787129116058714112_n.jpg49327542_336471703613531_7030442781550051328_n.jpg49450595_1965014850279962_1001008653081247744_n.jpg49057059_389158691829273_5787129116058714112_n.jpg
My main hoop has "plinth" mounts welded to all three surfaces (Rail, floor, and firewall), with build-up off the floor to make them level. Also uses a LOT of surface area contact area.
Are you prepping for a fuel cell... might as well at this point.
We are not, we would not be able to add any volume without incurring a penalty. It would have to be a stock size, and I am not sure it would be worth the effort/potential problems.
A little update on this project while I am here though, We decided to go with a halo style cage, Main hoop and Halo are bent, and we will be working on the uprights, dash bar and front shock tower bars this weekend. Hoping to get this wrapped up ASAP, so we can get to work on getting the thing back together.
https://www.instagram.com/zr3surrection/
Here is our team's instagram page if any of you are interested in that. Not a whole lot on there at the moment, but should be updated every weekend.
Didn't get a whole lot done on the cage yet, but we did do some work tightening up the butt. Used Izzy's custom cages's diff reinforcement kit to beef everything up. Overall, pretty good kit, but the actual diff mount was not lined up correctly for the Z3. The ears were supposed to drop straight down from the crossmember, but that just does not work on the Z3. Maybe that is the way a 318 lines up or something, I really don't know. Anyway, we re-engineered it, did some more cutting and what not, and it all worked out.
This was how it was originally set up, Two ears through the pre-cut slots. But that would not line up at all.
So, we cut a new slot, 15/16 forward, and modified the front ear with a bit of 1/2 inch channel
I made this sweet ass jig to keep everything lined up. I am not the fabricator of the group, and my measuring skills are elementary at best, so I gotta do what I can to make sure everything stays straight.
Also, been stripping some wire. It sucks, and is nerve wracking.
And here are some of the fellas bending some things. Except for Zach, he don't bend.
Also, not sure if I ever posted this or not, but here is a picture of the car after the wreck. Got pretty lucky there wasn't more damage really.
Looks like some of the guys on our crew. One guy won't pay attention no matter what's going on. Bar ain't gonna bend itself dude...
Nathan in Denver
Got quite a bit more done this weekend. Didn't really get a lot of photos yet, but I will try to do better this week. Anyway, we got the floor back in the trunk, we cut out the spare tire well, and the two cubby things that hang down behind the rear tires so we could have a completely flat trunk floor. This should help to reduce some drag. Also got a lot of the cage welded/in. still have the door bars and harness bar to make, but everything else is cut and fitted. Main hoop feet still need to be welded in, and then we will have some sheet metal work to fill holes.
Got the subframes and trailing arms blasted, and after adding reinforcements, they are getting painted.
Zach has started buying/selling Teslas, and we are trying to find how many bodies will fit in the frunk. Seriously, I drove this car around this weekend, and they are amazing. This is one of the sport, or performance models, (not up on my Tesla lingo) it is quick, and is the best road car I have driven. Kinda want to get one.
Also, we now have a FB page as well. If you are on FB, please follow us. (we are trying to do a thing)
https://www.facebook.com/Zr3surrection/
Nice work so far! Will be great to see a Z3 coupe around at the WRL races. What are you targeting for you first event?
We were really hoping for Barber, but a few of the guys had a busy streak at work. Road America will be our first event. Probably try to do a NASA TT, or something as a shakedown though.
What are you guys driving?
Got some more stuff done/started. Door bar on the driver side is in, waiting on another piece of pipe for the passenger, other than that, and the harness bar, we are done with the cage. I got started on the dash, and will hopefully finish that up tonight. It is set up to come out in one piece with about ten bolts. (If it all works out )
We also did an x bar for the front strut towers, copying CMM3's car. It is slightly different, but the same intent.
Here is a better look at our mounting points, and the door bar.
Here are a couple shots of last night. Got most of the dash welded up. Still have a couple of fill in panels to put in on the sides of the console, and some smoothing to do (it was welded in car, so a lot of vertical beads, and tight quarters, and different gauges of material), but overall, pretty excited at how it turned out.
51838857_299418300772603_6779334035370934272_n.jpg52353307_343696089568485_562095727375810560_n.jpg
51682738_1769963759775666_7850918608967303168_n.jpg51734086_269029357341818_6344609566067523584_n.jpg
Roll cage should be buttoned up this week, and the car should be back to rolling status on sunday/monday. At that point, we can get it back to my garage, and really start getting to the fun stuff. It should be a pretty sweet build. Our team has a huge spectrum of talents, and it will be really interesting to watch how it all comes together.
Got the wire harness bagged up last night, hoping to weigh the wire I removed tomorrow. It will be interesting to see how much weight came out. Also got our hubs from Core4 Motorsports. They do a press in stud conversion for BMW's, and since we will likely be doing an AER race, and they require studs, we had it done. I have seen screw in studs break, and what happens as a result, and have been using lug bolts up until now.
We have a couple of E36s. Our current one is a 323is we run in GP2 (pic below) and I am building an M3 (thread: https://www.bimmerforums.com/forum/s...-Enduro-E36-M3). We will be at Barber, but are skipping Road America for the first time ever do to a scheduling conflict for one of our guys, but may make Daytona instead. One of our team members and our old mechanic both have M Coupes, so I have a soft spot for them.
