Results 1 to 25 of 32
Thread: OEM BMW battery vs third party
    Apr 2018
    Seattle, wa
    bmw z3
    Hey, now that it's getting cold the battery in my 02 Z3 3.0i is draining really quickly.
    If it sits for 3 days the battery will be about 7 volts.
    It's not even really that cold: 40s and 50s in the day, mid-30s at night.
    It may be time for a new battery, which is fine. But I'm thinking I might be better off with a high quality 3rd party battery instead.
    What I have now is part #61 21 2 353 806.
    Any thoughts?
    Thanks,
    L
    Any battery that meets the correct specs is fine to use
    PRICE CUT on ALL FABRICS
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    Another one of those items that’s priced all over the map. Agree, it’s all about specs. The most expensive isn’t necessarily the best.
    i was fortunate. While scheduling pickup from the out of state dealership on my newly purchased roadster, they discovered the battery was nearing the end of its life. They promptly put a brand new 5 year warrantied battery in on their dime. Nice.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    There are many batteries that meet specs.
    BMW battery 61 21 8 381 738
    Duralast Platinum H6-AGM (AutoZone, comes with vent hose)
    Interstate MTP-H6 Megatron (NAPA)
    Sears DieHard International Gold H6 AGM
    Walmart Ever Start MAXX H6
    Pep Boys Bosch Performance #48 H6
    AutoCraft Platinum H6-AGM
    But they all need to be tended through long periods of inactivity in the winter climates.
    BMW MOA 696, BMW CCA 1405
    Oct 2018
    West Bend, WI
    Agree. Running a Battery Tender Jr. during winter layup.
    May 2013
    USA
    2001 Z3 3.0/5 roadster
    I think it best to go dealer battery. My last one went 11 years. The new dealer one is made in Austria and was only marginally more expensive than third party. Of course no fitment problems.
    Oct 2018
    West Bend, WI
    11 years is pretty sweet. What was the cost of the battery?
    May 2013
    USA
    The battery was $165.74 on 11/9/17. They carried it to my car, I popped it in and they took the old one away. The quality of a BMW battery is nothing to snicker at.
    Oct 2018
    West Bend, WI
    Hopefully the same source for my 2017 BMW motorcycle.
    Mar 2004
    Blue Ridge Mountains, NC
    1999 Z3 Coupe
    Dealer replaced my original battery after 3 years. Since then it has been on a tender if parked for more than 4-5 days. It lasted 11 years. I replaced it with a Autocraft Gold 48H6 from Advanced Auto and its now going strong after 5 years. It was a little short so I put a folded paper shim between it and the hold down strap. I'll tell you in another 6 years if it beats the oem.
    1999 2.8 Z3 Coupe
    Arctic Silver
    Washington, D.C.
    S54 e36/8
    I've had the Autocraft ones in both of my cars.
    M Coupe must have a short somewhere as it's killing batteries. I need to go mess with it and my multimeter...
    May 2015
    Maryland
    1998 M Roadster
    I did some research into batteries when I put up some solar panels. Want the battery to last longer, some suggestions.
    Buying the proper size battery limits the amount of discharged during starting. All batteries have a limited number of charge/discharge cycles.
    Keeping them charged increases life, batteries discharge while not in use.
    Keep the battery charged, they do not do well when deep discharge. See curve below. Overcharging will also damage the battery so use trickle chargers when stored.
    Some batteries are built better then others. Deep discharge batteries are built to resist the effects of deep discharge but cost more $$. Normal auto batteries have a good life for the money.
    Heat reduces life, not much you can do about this if you live in a hot climate.
    I tend to buy batteries from the same manufacturer if they last. Sometimes you just have to buy what is available for a reasonable cost.
    Cost.... no matter how much you pay, they will go bad over time. I get about five years out of Auto zone batteries in my cars and the replacement cost of keeps going up!!!
    Oct 2018
    West Bend, WI
    Good information. Any idea what percentage of charge they lose just sitting, as in storage month to month?
    Feb 2014
    Galt,CA
    2002 M Coupe
    I always love battery discussions. In my prior life I was in charge of a Telco central office, which had an AGM battery bank that was 6'x6'x40' in size. All AC coming into the facility was converted to 48VDC and fed into the battery bank, which supplied all of the telco equipment and ran inverters to provide all of the AC for cooling systems, etc. Nothing was directly powered by line AC. The rooms that had electronics in them were kept at 62 degrees, but the battery room was kept at 80 degrees. One time the main AC transfer switch fried, so we didn't have access to either line AC or our backup generator. That battery plant put out over 1400 amps of 48VDC for over 12 hours before they were able to get a new switch installed and operational. Now that's a battery!
    Marty
    May 2015
    Maryland
    1998 M Roadster
    Quote Originally Posted by Tigershark48 View Post
    Good question, I have never seen a spec on a battery for self discharge rate. I suspect it is related to how well the battery is maintained charge/discharge, the quality of the lead and acid solution and general construction of the plates and interconnects. I did a quick search and found this chart for power sonic batteries. Appears if you store the battery in below freezing conditions, the discharge is really low. There is a discharge amount (right side of chart) were the battery may fail to fully recharge.
    http://www.power-sonic.com/images/po...hManual-Lo.pdf
    Oct 2018
    West Bend, WI
    Very neat.
    My attached garage, where my cycle and car are stored, stays anywhere between 40 and 55 degrees F throughout the winter. Your chart tells me it would be 6-10 months before the battery would require charging to start the vehicle. As long as it gets charged before starting the car, it shouldn’t experience any damaging extreme discharge rate. Based on that, I personally don’t need to trickle charge it over winter. Since it’s a brand new battery, that would definitely apply this winter. I have my tender on my motorcycle and planned to swap it back and forth with the roadster, but it looks like I don’t need to do that.
    The cycle is a 2017, so it probably does not need trickle charging over winter either. If we have one or two perfect days to ride, I could just put the tender on the night before, so it’s at 100% when I start it.
    Please correct me if I’m wrong.
    May 2015
    Maryland
    1998 M Roadster
    The curve is from one manufactures batteries, results could vary. You also have to consider the current draw from the cars systems. You could disconnect the battery to eliminate that draw. You also might want to make sure the battery is 100% charged before storage and before first start. If you can run a cord outside, a small 12V solar panel works well.
    Oct 2018
    West Bend, WI
    Good point. Anything is possible including a very low level short somewhere, how much the clock draws, etc.
    To chart this myself, do I need more than month to month voltage change?
    May 2015
    Maryland
    1998 M Roadster
    Once a month should do. You will have to take accurate voltage reading, the difference between a charged and uncharged battery with no load is a little over 1.5 volts.
    Oct 2018
    West Bend, WI
    How does the voltage drop correlate with the percentage capacity chart you show? For example, at 9 months at 50 degrees? I’m trying to understand how I could accurately build the same type of chart for my stored roadster.
    May 2015
    Maryland
    1998 M Roadster
    Look at the pdf link, figure 5, open circuit voltage. The rate looks linear with a no load voltage of 11.5V for discharged and 13V for fully charged. I suspect the fully charged voltage will change a little from battery to battery depending on manufacture and health of the battery.
    Oct 2018
    West Bend, WI
    Thank you sir. I missed the .pdf link before. I’ll study the entire .pdf to try to get more up to speed. I looked at figure 5 and that appears to tell me what I need to know to track the unloaded discharge rate over time monitoring voltage during my storage period. If I have more questions, I’ll let you know. I intend to track it weekly for the month of January. If the loss is as minute as expected, I’ll extend measurements to monthly through the rest of the winter layup. I’ll post my findings this Spring. I also plan to pull the tender off my motorcycle and document the storage discharge rate the same as the roadster. I’ll skip riding it this winter on any surprise perfect weather days to complete the study.
    Fun stuff.
    Apr 2018
    Seattle, wa
    bmw z3
    Thanks for all the recommendations and advice.
    I think my OEM battery is still good.
    I usually keep my Battery Tender plus on my motorcycle this time of year.
    Before posting this, I had put it on my Z3 to bring it up to 12 volts and then drove it around for a while. Apparently that wasn't enough.
    This time I left it on until the meter showed 14.4 volts, and wouldn't go any higher.
    Since then, it's holding a charge normally, and not draining between drives.
    L
    SW Florida
    99-01 M Cpe & Rdts, X5M
    If you have a Tractor Supply Co. (TSC) in your town, their Schumacher tenders are very inexpensive and seemingly indestructible; I've got five or six (5-6?) of them to cover my own cars and the occasional long-term customer's car.
    A few years ago they went through a design re-engineering, that reduced their weight considerably, probably from a XMFR to inverter-type technology (?) but I've yet to have either type fail and they're in use 24/7.
    I don't think I've ever paid more than the $20.00 they're on sale now for either; good value and negligible investment (Christmas Stocking Stuffer candidate...).
    https://www.tractorsupply.com/tsc/pr...a?cm_vc=-10005
    For convenience, Amazon has them (duh...) for only a few dollars more.
    https://www.amazon.com/Schumacher-SC...=1545142365117
    Oct 2018
    West Bend, WI
    Can’t beat the price.
    Do you hook up directly to the battery in the trunk, or to the jump terminals under the hood or do you take the battery out of the car?
  1. Used OEM BMW Battery. Came out of a '98 750iL
    By bmwtransport in forum Car Audio & Electronics
    Last Post: 02-27-2010, 03:47 AM
  2. OEM BMW battery MFG date 19-07
    By gtxragtop in forum Whole Parts Cars
    Last Post: 09-27-2009, 07:53 PM
  3. BMW Parts VS. Third Party Parts
    By wardy24 in forum 1996 - 2003 (E39)
    Last Post: 08-12-2008, 01:55 PM
  4. Replies: 5
    Last Post: 08-20-2007, 01:55 PM
  5. OEM BMW battery or Optima Battery
    By Turbofans in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-08-2006, 11:24 PM
