Results 1 to 5 of 5
Thread: Front end noise e46
    Jul 2018
    Washington
    99 e46
    Front end noise e46
    I have a 99 328i, and when I'm turning to the left while moving at atleast 15mph I get a bad noise from the left front. It almost sounds like a wheel bearing that's about to fall out. But I've checked just about everything. And it's only when I'm turning left and moving.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    It’s not likely a wheel bearing. When turning left the weight of the car shifts to the right side of the car. So, the right bearing would make the noise. Does the noise increase in volume when you increase the speed? Does it change in tone when the speed is increased? Has the carhad work done on the front end recently?
    Jan 2017
    USA
    E21, E46
    Also double check your wheel lugs to ensure they are torqued to 88ftlbs.
    You can lift the car up , lock the steering wheel and try moving the front and left wheels left to right right to left and up and down to see if you have any extra play in the bearings or suspension.
    Aug 2009
    Silver Spring, MD
    03M3 17M540 18A5SB
    Quote Originally Posted by MarcoZandrini View Post
    What also happens when you turn left is the right side suspension compresses and twists the front sway bar through the sway bar links. The noise could be a broken or worn left side sway bar link or even a bushing. In any case you'll need to get the car up on jack stands or a lift to get under it and see what's what. If you're handy you might be able to reach under the front to the left front swaybar link and feel if it's loose while the suspension is loaded (car on the ground).
    Jul 2018
    Washington
    99 e46
    The only front end work I've done on the car was the control arms and bushings when I got the car. Theres no play in the front end and the noise gets faster as my speed increases. And I know my wheels are tight. I havent taken too close a look at the sway bar but I'll be sure to take a look.
  1. E46 left front end noise.
    By lumorales1997 in forum 1999 - 2006 (E46)
    Last Post: 09-19-2012, 08:32 PM
  2. Front end noise - need help narrowing down what it may be..
    By gota525i in forum 1996 - 2003 (E39)
    Last Post: 05-20-2005, 12:39 PM
  3. Help E36 Front End Noise driving me crazy.
    By Ken's 323is e36 in forum 1991 - 1999 (E36)
    Last Post: 03-22-2005, 02:16 PM
  4. front end noises!
    By mcoupejeff in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-04-2005, 10:34 AM
  5. Front-end noise while slowing down, 95 M3
    By owen in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-04-2002, 09:01 AM
