I did the timing chain guide job on 2002 e39 540i m62 with vanos , I also did all the chains and tensioners , all new gaskets for that , all new gaskets for intake , cleaned everything nice , blew any debris out of intake head part of motor where Intake attaches , had the cams blocks on the whole time never really moved , crank pin in flywheel , set the timing with tension on chain and pins out of tensioners on cams , got both vanos to read 0.00 .0.03 ohms then I torqued both cams to 93 and 83 ft pounds , then i install the ring plate on the vanos with the special tool that bolts on top timing cover to 36 ft pounds or so and then pretty much reassembled everything took the cam blocks off then the flywheel pin nothing seemed to have moved I had continuity before I installed everything , also probably 250 ft pound on crank bolt I have it all put back together then put battery cable back on and when I go to start the car it doesn’t even go click click click like it wants to start , it kinda jus makes a small click and I don’t know what to try first ? I got a charged battery at 12v please help
Any codes?
e34 540i/6 :: e30 M62/6 :: e30 318is :: c5 Z06
Haven’t scanned the car yet , will try tomorrow when I get out of work
