Results 1 to 7 of 7
Thread: Front Passeneger Window Regular Replacement
    Oct 2016
    Denver, Colorado
    1997 BMW 740i
    I’m replacing my front passenger window regulator and I’m wondering how to disconnect the glass from the regulator, to take the glass out.
    My window is almost up all the way, and it for sure won’t go up. I think I can make it go down. Do I need to lower it, and will eventually see the bolts to remove? Do I need to somehow get it to go up all the way?
    1997 BMW 740i
    2006 BMW X3
    Apr 2003
    Seal Beach, Ca.
    2003 540s, 2000 740s
    Here's a very good DIY:
    http://www.bimmerboard.com/forums/posts/885621
    e38.org has other DIYs you could check out.
    <== Steptronic Sealbeach740
    2000 740i sport: 74k Green/Tan chrome MPars, clear corners, quad brake lights, AIC hi-beams, Hoen fogs, 16x9 screen, MKIV, TFT LCD screen in back, license plate backup camera with "on demand" switch, iPod audio/video (CDC/iPod audio switching, iPod video on 16x9 screen), Basslink, gauge rings, ///M pedals, switched steptronic +/- shifting mode, E46 paddle shifter steering wheel, Dinan engine & tranny software upgrade, DDEs controlled via Euro fog light switch, painted calipers with "BMW" lettering, windows up/sunroof close via remote.
    2003 540i sport: 81k, Sterling grey/grey, MKIV Nav, PDC & CWP - Added license plate backup camera with "on demand" switch, paddle shift steering wheel, windows up/sunroof close via remote, Akebono's, painted calipers with "BMW" lettering, quad brake lights, iPod audio via AUX mode/video via 16x9 screen, BMW TV tuner, ///M pedals & gauge rings.
    Oct 2016
    Denver, Colorado
    1997 BMW 740i
    Quote Originally Posted by sealbeach740 View Post
    Thank you. I also disconnected my airbag, even though it says not too. Is that an issue?
    1997 BMW 740i
    2006 BMW X3
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    As long as you reconnect before starting the car or turning key on it’s not a problem. If you start it with it disconnected the airbag light will come on and need to be reset.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Rutland, Vermont
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    When you get the regulator out, please tell me which pulleys failed (upper or lower). Curious.
    Frankie
    Texas, USA
    frankies-bmw.com
    Apr 2009
    Land O Lakes, FL
    1986 535i, 2012 X5 50i
    You can cut the steel wire and the window will be free to move. That's what I've done.
    Jimmy Moreno
    BMW CCA 115551
    1986 535i, Arctic Blue
    2012 X5 XDrive 501, Sparkling Bronze Metallic
  1. E32 window regular replacement, rail sliders (note)
    By unity in forum 1988 - 1994 (E32)
    Last Post: 06-30-2017, 04:54 PM
  2. Replies: 0
    Last Post: 09-02-2007, 08:35 PM
  3. Reasonable price to replace front pass. window?
    By quattro PETE in forum 1996 - 2003 (E39)
    Last Post: 04-03-2007, 10:58 AM
  4. Front Window Trim Replacement
    By 95werksm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-19-2006, 11:41 PM
  5. Replies: 3
    Last Post: 01-02-2006, 11:00 AM
