Results 1 to 3 of 3
Thread: wiring harness junction box under throttle body
    Dec 2018
    Brentwood, CA
    2007 328i
    I have a 2007 328i N51 engine. I pulled the intake manifold and the wiring harness junction box under the throttle body. Now I'm putting it back together and have a plug left over and can't figure out where it goes. It's a short cable so has to be close but I don't see anything it could plug into. In this link you can see the plug: https://photos.app.*******/zuHz75FRXXKr5FRj8
    The wiring harness is part # 7555016 but I couldn't find a wiring diagram for it. Hoping someone can tell me what I'm missing here.
    Some more info on this. Problem is, I can't get the engine started. When I try to start the engine it cranks over and sounds like it can't get enough fuel. It will labor and then start for a second and then quit. Giving it gas with the gas pedal doesn't help. Only code it's throwing is 2D5A (Monitoring engine torque limiting) which I don't think is much and 2D0F Air mass sensor. I did disconnect the mass air flow sensor but have it connected to the air box now.
    Dec 2018
    Brentwood, CA
    2007 328i
    Picture still doesn't work.
  1. M52TU engine wiring harness connector box
    By Aussie528iT in forum 1996 - 2003 (E39)
    Last Post: 01-29-2018, 07:17 PM
  2. Replies: 9
    Last Post: 12-22-2015, 10:40 AM
  3. Replies: 7
    Last Post: 09-17-2014, 03:48 PM
  4. Replies: 7
    Last Post: 02-23-2008, 11:18 AM
  5. WTB: Accordian boot from CIS box to Throttle Body
    By vtgti in forum 1975 - 1983 (E21)
    Last Post: 03-05-2007, 12:08 PM
