Results 1 to 6 of 6
Thread: Left Exterior Door Handle Problem - In Hot Weather
    Dec 2018
    Travelers Rest, SC
    1996 BMW Z3
    Tried searching thru, but couldn't find anything in Z3 area with this problem. Maybe I just overlooked.
    We have a '96 Z3 1.9. In the hot summer months, in order to open the driver door you have to reach in thru the passenger side and open the drivers door using inside handle. This only happens AFTER the car has been outside.
    Had her in the shop on an unrelated issue the other day and asked the mechanic about it. He said the cable was probably stretched and need to be replaced. Then hit me with a $600+ estimate to fix. From what I've researched, it seems the cable is what connects to inside handle with the latch mechanism. If so, then it would seem I need to replace the exterior door handle assembly.
    Any help would be appreciated!
    Rick
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Try adjusting the latch striker (car side, not door side).
    Open the door, loosen the two Torx bolts while leaving some tension on them (think snug enough to hold the latch in place but not so loose that it slides around too much). Close the door with handle held up. Open the door. Tighten the bolts. Save $600.
    http://www.bimmerforums.com/forum/sh...-having-issues
    Nathan in Denver
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    You may want to just try putting some white lithium grease on the latch contact point before doing anything more drastic.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Oct 2017
    Los Angeles, CA
    2000 S54 - Mcoupe
    This just happened to mine too in these last couple days. So annoying.
    I'll try the WD-40. If nothing happens, I'll mess with the striker itself.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by z3m.casey View Post
    ... I'll mess with the striker itself.
    Reading for latch and striker:
    http://www.bimmerforums.com/forum/sh...hlight=striker
    http://forums.bimmerforums.com/forum...or-Striker-DIY
    BMW MOA 696, BMW CCA 1405
    Nov 2011
    hickory, nc
    2000 bmw z3 M
    my m roadster passenger side door handle needed some help . sprayed some white lithium grease and fixed it instantly.
  1. Exterior Door Handle Problems
    By HeliHover in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-01-2016, 03:53 PM
  2. Replies: 0
    Last Post: 11-25-2012, 02:15 PM
  3. WTB- E36 left exterior door handle
    By skate1bmw in forum BMW Parts Wanted
    Last Post: 06-05-2010, 06:08 PM
  4. E39 528i Exterior left front door handle.
    By iiiww in forum BMW Parts Wanted
    Last Post: 01-24-2009, 09:45 AM
  5. Exterior Door Handle Trim Problem.
    By BIMMERLOVR in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-18-2004, 01:59 AM
