Results 1 to 5 of 5
Thread: hood release cable broke
    west new york,nj
    328i
    E36 98' 328i release cable handle has no resistance and hook is closed so I guess the cable snapped. After reading posts in the forum, I just realized I need to lubricate the latch regularly. My latches and lock are rusty and lock sometimes stuck a bit.
    Checked a few youtube and posts and below are my options:
    1. remove the kidneys /grill and try to locate crossover cable to pull (with a mirror)
    2. from bottom to locate cable to pull at the driver side
    3. get rid of driver side side signal and locate the passing cable
    4. harder way is to remove bumper, aux electric fan and locate crossover cable
    Any remaining latch can be opened with bend screwdriver.
    Questions:
    1. is #1 suggested way to open the hook in terms of time and feasibility?
    2. I guess I need to replace the whole latch, cables, right?
    from oem chart http://www.realoem.com/bmw/enUS/show...diagId=41_1048
    Besides 7,15,16, 20, what else to replace?
    3. saw the post in E39 forum, not sure how it applies to E36.
    "Replacing the latches &/or cables requires removing the bumper and electric auxiliary fan to make space to wriggle the latches out of their mounting pockets. This isn't as bad a job as it looks - depending on how fast you work 15 to 30 minutes to remove both for space to wriggle the latches out. And it's a one person job although one would think that you'd need two to remove and refit the bumper. There are DIYs around, both written and video."
    https://www.bimmerforums.com/forum/s...+release+cable
    Thanks a lot.
    EDIT: pelican parts has an article about how to replace:
    https://www.pelicanparts.com/BMW/tec...eplacement.htm
    Apr 2015
    Tennessee
    1998 BMW 328i
    Id pull the handle off first and check there, and if that doesnt do the trick I'd go thru the driver side headlight.
    Jan 2018
    Earth
    I've never had to do it, but if I did I'd go behind the turn signal.
    west new york,nj
    328i
    So I need to replace all of hood catch, upper part of hood lock, and lower part of hood lock, both cables? Anything else?
    west new york,nj
    328i
    The trick of one person pull the cable while the other is wiggling the hood works. But I won't do it again until all the replacement parts arrive.
    Meanwhile I failed to use tennis string to make a backup release mechanism. I'm not sure if I should tie the string to the middle cable connecting both latches the next time I open the hood.
  1. Hood release cable broke. My prob is more serious.
    By Black540Msport in forum 1996 - 2003 (E39)
    Last Post: 12-19-2017, 08:45 PM
  2. Blasted Hood Release Cable Broke Getting the Hood open again Nightmare
    By CMM3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-13-2012, 09:51 AM
  3. hood release cable broke! how do i open my hood?
    By trnc in forum 1992 - 1999 M3 (E36)
    Last Post: 07-24-2009, 06:52 PM
  4. Hood release cable broke
    By bostongreen328i in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-22-2008, 01:07 AM
  5. Help on Replacing Hood Release Cable
    By 95///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2005, 06:32 PM
