Results 1 to 6 of 6
Thread: Clutch noise
    May 2017
    Austin Tx
    e34 525, s52 1993skyline
    Clutch noise
    So I've swapped in an s52 with a zf trans into my e34 and installed a new clutch and pressure plate with a throwout bearing but now when it idles im getting a rattling noise unless i push in the clutch then it goes away. has anyone else had an issue like this? I did some research and tolked to some of my friends about it they think it could be the throw out bearing but from what ive read the its normally the other way around meaning when the clutch is engaged it would make a noise. Is this correct or am I misunderstanding?
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    If you used a lightweight flywheel, that’ll rattle.
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
    May 2017
    Austin Tx
    I used the stock fly wheel with a sachs clutch but not OEM it was a bit beefier then stock. but it came with pressure plate bearing and all that jazz. I also replaced the bolts with some grade 8 ones.
    moroza's Avatar
    BFE
    E34T
    By "stock", do you mean the original dual-mass? Those don't usually rattle at idle but I guess it's possible.
    Push the clutch in slowly and see if you can determine whether the noise goes away as soon as there's any pressure on the pressureplate, or if it requires full disengagement of the clutch.
    May 2017
    Austin Tx
    Quote Originally Posted by moroza View Post
    ill try this today and get back to you.
  1. Clutch Noise...
    By Saloon325i in forum 1991 - 1999 (E36)
    Last Post: 09-09-2004, 10:50 AM
  2. 93 325is strange clutch noise
    By Snake Deadly in forum 1991 - 1999 (E36)
    Last Post: 08-24-2004, 10:18 PM
  3. Uuc Ltw Flywheel And E34 M5 Clutch Noise
    By jay00f4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-26-2004, 11:18 AM
  4. Funky Clutch Noise
    By dcardenas in forum 1991 - 1999 (E36)
    Last Post: 02-13-2004, 11:44 AM
  5. clutch noise in neutral
    By Ian in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2001, 01:49 PM
