Decided to replace my coupe trunk handle gasket as it’s crumbly and gross. Ordered up a replacement one referencing my vin on realOEM. PN is 51227026400.
Now there are two part numbers listed. That one as well as 51228401010. I looked at images of both and it appears that the layer is for the smaller handled trunk lid pieces whereas the one I ordered (-6400) is a larger one.
I can’t actually confirm that. Regardless the -6400 part showed up and looks like an almost perfect fit. Except it doesn’t fit. It’s too short by about 1/8th of an inch on both sides. I can stretch fit it andnmake the gasket sort of fit. But as soon as you try to actually instal it on the car the gasket will peel back.
Has anyone had experience with this before? Did I simply make a mistake and order the incorrect part? This gasket is so freaking close to fitting I have a hard time believing the other one could be better.
I’m at work right now and can’t link pictures. I have several that I will add over lunch or so forth.
Any insight on which gasket is the right one? Or if the correct one simply isn’t being produced perfectly and requires a stretch fit? Thanks in advance. I’m running no gasket right now because it’s such a questionable fit.
Ok, here are some pictures:
look how close the fit is - but you can see its a bit shorton the sides:
also, although the inner ribbed parts are generally on point, you can see how putting the gasket over the two smaller holes causes the center lock hole to be distorted enough that it will not sit flush into the recesses
tell me I am not crazy here - more pictures of imperfect fit showing how you can totally lip it over and make it work.....temporarily. Once lifting pressure it immediately shrinks back
almost all of the pieces fit into grooves. Except for the outermost socket that appears to want to sit over a male plug on the trim piece itself, except there is nothing there on the trim side so....
OEM supplier or aftermarket? I replaced the shorter one on my '99 and it fit perfectly. Twer me I'd return and try another suppler.
Blue Ridge Mountains
1999 2.8 Z3 Coupe
Arctic Silver
Genuine BMW part from online vendor (FCP Euro). Do you remember the PN on that? If it's 51228401010 then I can rule that one out and know mine is the "correct" (eyeroll) part
EDIT: yeah looks like 51228401010 is definitely not the correct part, meaning what I have is the correct part but simply has a terrible fit?Capture.JPG
I had the same issue but for the smaller handle, no resolution yet. Was gonna worry about it if I ever found a chrome handle to install
PRICE CUT on ALL FABRICS
Sorry can't find a record of purchase, but realoem says my part # is 51228401010. Have you contacted FCP? Their customer service is top notch.
1999 2.8 Z3 Coupe
Arctic Silver
Maybe a little Krazy Glue applied to the ends of the gasket? This is what was done to my E-type bumpers to hold the gasket on prior to offering them up to the body and brackets.
Wayne
1998 M Roadster
1994 Honda ST1100--sold
2017 Yamaha FJR1300ES
Update - this part is indeed the correct part. The fitment is horrendous. But I made it work. The secret here was using liberal amounts of butyl tape inside the little finger parts as well as the tips. Even so it's tricky and you end up having to use a plastic tool to pry out the edges around the entire gasket until it's perfect. Very time consuming and also easy to nick the gasket so it rips. I had a few small knicks myself but overall happy with the final look. Enjoy:
Looking good. Butyl tape was a great idea. Too bad you were forced to such extremes.
1999 2.8 Z3 Coupe
Arctic Silver
yeah seriously. easy in theory to replace the gasket.....turns out to be an hour long process after a few days of brainstorming.
Ed McKernan at BimmerBum was able to source one of the correct size. We are hounding him to find more for us to buy...
