Results 1 to 10 of 10
Thread: ABS Dsc fault above 25km/hr
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Hello every body, I have in my e38 740 1998 ABS DSC lights on , first time when gets rain and speedo not working , The left rear sensor has bad wire I replaced the wire and reconnected it , the speedo works , but the abs dsc light comes on when the speed above 25 km /hr
    I use inpa the sensor not mentioned in error ( chassis > dsc sector )
    Any one can help me please
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    That could be pre-charge pump failure - but could also be another wheel sensor failing - you need diagnostics to determine which it is - pre-charge pump covered in the second section of this:
    https://www.meeknet.co.uk/E38/ABS/Index.htm
    My BMW Repair YouTube Channel
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    What is the error you are getting from inpa?
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I tried inpa but no any error about sensors even when the rear left is failed , only I have steering angle sensor pulsating
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Quote Originally Posted by haydar alameen View Post
    That will do it! Hopefully you just need to re-calibrate it which can be done via diagnostics.....
    Mar 2014
    Iraq
    1998 BMW e38 740i
    It occurs due to failure of the front rod , I fixed it today and the angle is zero when the steering wheel in its standard position, I previously had this problem with steering angle but only DSC light switched on , and I recalibrate it .
    I jacked the car and moved the left rear tire the speed reaches 60km/hr and no error found
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, that would certainly do it - well done!
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Sorry for my poor english , I mean the pulsation was caused by faulty rod when I replaced it and did alignment the pulsation in steering wheel resolved , but the DSC ABS light still turn off above 25 km /hr
    no error by inpa ( its seem that the abs sensors not coded within it ! )
    I jacked the rear left wheel and moved it ( turn the engine on ) The speed reaches to 60km / hr with no dsc abs light , that is mean the problem not in the system as the car knows it is moving , I am right ?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    It is the pre charge pump
    Sent from my iPad using Tapatalk
    Nov 2011
    Busselton Western Aust.
    2009 F02 740Li
    If I am reading this correctly can the ABS lights come on if a wheel is out of alignment? I have noticed my passenger front has worn badly on the outside edge and now pulling left and my ABS lights come on but I dont lose power steering function, speedo etc like I did on my M5 when it's unit died. 1996 750il but I am not getting any error codes with Torque Pro
    2009 F02 740Li
  1. ABS/DSC fault 81 - internal relay?
    By kaivonp in forum 1999 - 2006 (E46)
    Last Post: 08-26-2016, 12:50 PM
  2. E38 750i ABS, DSC, Speedo, ECO, fuel gauge fault
    By robshaw in forum 1995 - 2001 (E38)
    Last Post: 11-19-2015, 03:04 AM
  3. Replies: 2
    Last Post: 02-26-2013, 12:41 AM
  4. ABS / DSC Fault Help ;(
    By Miss BimmerLV in forum 1995 - 2001 (E38)
    Last Post: 03-21-2012, 11:48 AM
  5. Brake, ABS & DSC lights - no fault code
    By swb03 in forum 1995 - 2001 (E38)
    Last Post: 11-25-2009, 04:03 PM
