Results 1 to 5 of 5
Thread: 335xi vs 328xi
    Oct 2018
    Portland, ME
    2011 328i xdrive
    335xi vs 328xi
    Hey bimmerforums, so I’m in the market for a new car and looking at either a 2008 335xi with 65,000 miles for $8,000 or a 2007 328xi with 65,000 miles for $7,000.
    I’m leaning towards the 335 however my understanding is maintenance tends to more expensive and prevalent than on a 328 or 330. I was curious what you folks might have for thoughts on which car might be the better/smarter buy both short term and long term. Pros/cons?
    I know there’s a ton of threads like this one out there so I apologize for the redundancy.
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    If you want the lowest cost of ownership, 328 would be the way to go. If you want to modify the car and get a little more power out of it relatively easy , the 335 will be much more fun and responsive to upgrades. They share similar issues (or preventative maintenance for most BMW's) , valve cover gasket, oil filter housing gasket, water pump/thermostat, plugs/coils and the valve covers can crack. Nothing else to major for the 328's.
    The early 335's have the N54. I have had some customers with only 80k miles need to replace the turbos. High pressure fuel pump is a common failure, the dealer will cover this to a certain mileage (check with your local dealer to see if its already been replaced). Fuel injectors have issues down the road. I might be missing some issues but this is what came to mind quickly. I have to say, the N54 is a ton of fun so it is not an easy decision!
    If you have any other questions, feel free to email me, seank@turnermotorsport.com
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
    May 2017
    Ontario, Canada
    335i E93 N54
    I believe seank has summed it up well.
    I've had a couple of each. I'm finding my 335i is significantly more maintenance, but I have also upped the boost and associated requirements.
    For the first time ever, I got a beater car to drive while I'm working on my 335i... pricey if you just pay for all the labor.
    However, when the hard top drops, and 400+ whp hits, all the sweat and tears are left behind.
    Apr 2012
    Boston, MA
    09 335xi Man
    I looked at both and ultimately settled on the 335. I think it has bigger brakes and sleight stiffer suspension. It felt more solid when driven - something that surprises me since they are otherwise the same. Maybe, it was the specific cars we drove. I love my manual transmission 2009 335xi in light blue color. It’s been a great car, but I also don’t put a ton of miles each year.
    Fort Collins, Colorado
    2008 328xi Sportwagon
    Just hope the turbos don't give you problems. Rebuilds are expensive.
  1. 335i vs 328xi
    By nm335 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 06-13-2007, 01:49 AM
  2. 328i Coupe MT vs. 328xi Coupe MT
    By Justbringit41 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 02-17-2007, 06:14 PM
  3. advice: 328i wagon vs. 328xi wagon
    By TimG in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-24-2006, 03:24 PM
  4. 328I vs 328XI
    By Dvsone in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-01-2006, 08:14 PM
  5. Boxter vs 328xi Coupe
    By PeterC4 in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-27-2006, 09:48 PM
