Results 1 to 25 of 31
Thread: Reverse, one moment it was there, then it was gone.
    Dec 2004
    CT, USA
    e28, e34, e39
    2001 525it with 155k miles.
    15 minutes before, reverse was working fine getting out of the grocery store parking lot. Then I stopped off at the library to return some books and reverse was gone without warning. No faults are displayed on the cluster. Car just revs in reverse and all forward gears are working fine so I pushed it out of the parking spot and drove it home
    From realoem it looks like I have the A5S360R or 390R (not sure which) tranny which is the the same as the GM5L40 but I will verify this weekend when I put it on the lift to check fluid level and then drop the pan.
    Does the A5S360R have the same fragile reverse drum issues as the ZF5HP19? It would be nice if it's something as simple as fluid level or a solenoid. I've taken a manual tranny apart once so maybe I can do the same to this auto. Otherwise I'll take it down to the local transmission shop so they can take a look at it. And to think just the other day I was contemplating about how reliable this car has been since I bought it.
    cheers
    demet
    Los Gatos CA
    1987 325is, e34, Z3, e39
    Hmmm, you should be squarely within the parameters for having a 5HP19 transmission. And right at the border for the fix.
    A suggestion: take a picture of your transmission by extending your arm under the car. It take a few seconds and you probably won't even get dirty.
    The hard part is pulling the transmission. Disassembling the 5HP19 is *far* easier than a manual transmission. The only special tool you need is a top-quality T27 driver. Replacement screws are surprisingly expensive. Spend $5-$10 to get a tool-truck-quality driver that won't damage the heads. The T40 driver and the few other tools don't need to be anything special.
    At this age the torque converter might also be worth replacing. An internal seal fails, resulting in the lock-up clutch not reliably activating. That's not an operational problem, but people report that the warning light results in eventual insanity.
    You should plan on replacing the two plastic connectors to the oil pump, the large oil pump o-ring, and the input+output shaft seals. You could get lucky and not need any of those, but it's likely that one of the connectors will break during removal and you would feel silly if the inexpensive external seals leaked.
    There is a chance that you'll find hardened seals once you open the transmission. That requires a $150-$200 rebuild kit, and further disassembly. But even there it's mostly figuring out how to apply a few hundred pound of force with a few dollars of PVC pipe fittings rather than the custom bearing splitters and hydraulic press usually required for manual transmission.
    Dec 2004
    CT, USA
    e28, e34, e39
    Thanks djb2. I'll check it out tomorrow and snap a couple of pics and post them up. I was a bit confused by realoem not showing any ZF tranny for this car.
    demet
    Jul 2012
    mitten
    525it,02 525it,73 2002
    Would agree that it should be a ZF transmission. Sounds like classic reverse drum fracture. Two grand to have a shop do it.
    I had my Japan Red wagon repaired last Spring,had them service the diff also. My winter beater wagon had it done before I bought it.
    Good luck with it.
    Dec 2004
    CT, USA
    e28, e34, e39
    Did you bring them the car or just the tranny?
    demet
    Jul 2012
    mitten
    Quote Originally Posted by demetk View Post
    They did everything. I dropped it off and picked it up two days later.
    Complete rebuild and diff oil changed out. I didn't feel like doing it.
    Dec 2004
    CT, USA
    e28, e34, e39
    Wow, to me that sounds like a very good price. Or is that the going rate?
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    Newbie question. If it is the 5hp19 can the GM tranny be installed in its place?
    demet
    NW suburban Chicago
    hiss by my window
    At the very least you'd need the controller and wire harness(I think it is a discrete harness for trans on E39s?), probably driveshaft, maybe shifter.
    I know it's hard to discourage a guy who courageously puts the glorious M30 in place of an M60.
    FWIW I had a ZF 5hp grenade in a Jag a few years ago, $2k for the complete job. It's certainly DIY able but that pig weighs a friggin' ton and I didn't care to do the R&R on my back.
    Dec 2004
    CT, USA
    e28, e34, e39
    Thanks Ross, That 530i has been dead balls reliable with that m30 in it.
    Pics of the tranny,
    I don't know what I'm looking at right now, but I'm sure you guys must know. I'm going to drop the pan in a bit and see what surprises are waiting for me.
    Hmm, I wonder if a turbo'd m30/5 speed will fit in this touring. I have one just waiting for a new body.
    cheers
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    Early x-mas present, not much of a surprise. After all there had to be a reason for no reverse and a broken D drum seemed the most likely. Transmission oil was very black.
    Started to pull the tranny. Exhaust is down, what a monster.
    What's with the funky left extension on the resonator that leads nowhere?
    And what is the purpose of this strange part on the back of the muffler?
    That's it for tonight.
    cheers.
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    And it's out.
    Removal was very straightforward with a fused starter dowel pin the only issue and that was easily overcome.
    demet
    Los Gatos CA
    The factory transmission fluid is green. It only takes a little friction disk dust, or a top-off off with red fluid, to make it look black. Unless you clean it completely and replace the torque converter, replacement red fluid will instantly look "burnt".
    The resonators and counter-weight on the exhaust were very carefully designed. If you remove them you can figure out what annoying buzz they eliminate.
    You need to remove the valve body to pull out the two oil pump connector pieces. Roll the transmission upside down to remove the valve body. Fluid will leak out of the vent so put a cookie pan or diaper under it.
    Then stand the transmission vertically on the output flange to remove the major assemblies. Strap it to a post or the wall. Use your best T-27 driver to remove the oil pump screws, tapping each one before applying turning force. After that each assembly just lifts out, with only two or three more screws to remove.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    As DJ says. The first "lung" resonator as we casually sometimes call it, acts as a tuned Helmholtz chamber on the dead-end side. M5's actually breathe out the end of it for a dual exhaust, but all the other cars get it like that with one side plugged, but, it does work to cut resonant drone. The other is a counterweight or sometimes called "damper". It similarly is supposedly harmonically tuned to keep the end of the exhaust from vibrating and buzzing.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Dec 2004
    CT, USA
    e28, e34, e39
    Thanks for the replies. That resonator looks like someone cut off perfectly good section and installed a peg leg. I'll bet it costs extra that way.
    Where do you guys get your rebuild kits from? Eriksson Industries are 10 minutes away so I'll give them a call for some parts. They also have fully rebuilt trannies for $2k with a 1 year warranty. I may go that route if I fail at a DIY rebuild.
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    $331 for the following oem parts from Eriksson,
    Updated D (reverse) drum and 2 plastic tubes,
    O-ring kit,
    Friction kit,
    I'll evaluate where I am when I pull the tranny apart. If I feel I'll need additional parts then I can return the above and just go with the rebuilt tranny from Eriksson. Nate is supper nice and took the time to answer all of my newbie questions.
    Question,
    Is there a tranny computer chip available with a customized set of shift points? What I was experiencing was a very temperamental tranny that shifted at the slightest throttle input. It's possible that the tranny computer was overcompensating for the anemic engine but whatever it is I'm certainly not going to accept this type of weird behavior going forward. I'll definitely do my homework on this problem but figured maybe someone has an answer on this.
    Oh yeah, I do have the 5HP19 tranny.
    cheers and TIA.
    demet
    NW suburban Chicago
    hiss by my window
    The odd shifting could be the result of a wonky MAF. Once you've put it back together with a clean valve body it may not be an issue.
    Can't speak to custom shift points.
    You may want to have a very good look at the A drum while you are in there.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    O-ring kit,
    Does this tranny need the cone tool to shrink the (white?) o-rings on the shaft before you slide the drum on?
    Dec 2004
    CT, USA
    e28, e34, e39
    Hmm, I didn't see one used in the rebuild vids I have seen. I'll take a look and see what I can find.
    demet
    Dec 2004
    CT, USA
    e28, e34, e39
    Got it taken apart, surprisingly with only basic tools.
    As expected, the D drum was busted up.
    I managed to find all of the missing pieces.
    The friction and steel disks in the D drum looked really good so I think I may get away with replacing only the friction disks in all of the drums.
    This was definitely a great learning experience.
    cheers.
    demet
    May 2014
    council bluffs, Ia
    97 Z3 90 Porsche S2
    Job job, you are braver than i. I have replaced some seals and linkage before but never pulled a auto tranny appart before. My had the torque converter replaced on my car. I hope it's all I will need for a few years anyway.
    Dec 2004
    CT, USA
    e28, e34, e39
    I figured the worse that could happen is I grenade it when I finally put it back in the car and stick it into drive for the first time. But the work isn't over yet. I still need to take all of the drums apart and replace the friction disks which includes building a press to take the D drum apart and then rebuild the new D drum I bought. And finally hope that I don't put it back together all wrong. If you've seen an exploded view diagram of the 5HP19, it's terrifying.
    cheers.
    demet
    JimLev's Avatar
    Sundance Mesa, NM
    I was just curious, the 4L65e that I did a few months ago required one if the shaft o-rings were going to be replaced.
    Dec 2004
    CT, USA
    e28, e34, e39
    Thanks Jim, Do you have a source for that cone tool?
    demet
    JimLev's Avatar
    Sundance Mesa, NM
    I didn't need to use it, it's generally used if you are installing new o-rings on the shaft so you can shrink them to get the drum to slide on without damaging them.
    I'll dig up that info later today.
  1. Reverse Lights not working...Fuses OK
    By Seedster in forum 1991 - 1999 (E36)
    Last Post: 01-17-2007, 08:10 PM
  2. how fast have you gone in reverse??
    By axion911 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-02-2001, 11:47 PM
  3. '97 528 dies when put into reverse, any ideas?
    By Hua in forum 1996 - 2003 (E39)
    Last Post: 04-18-2001, 10:45 AM
  4. A moment of silence for this M3
    By BMWguy in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-06-2001, 05:56 PM
  5. A moment of Silence For this M3
    By BMWguy in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 12:45 AM
