Results 1 to 5 of 5
Thread: 320d not cranking
    Jan 2013
    Latvia
    E36 Touring
    320d not cranking
    320d does not crank, does not click. Bump starts just fine. After a small drive the starter works, but if I leave the car for like 6 hours. No click, no start, again. Once, during the time of the issue, it worked in the morning as well, but just once. Ews module clicks , when the key is put in and ignition turned, clicks after few seconds, after removing it. Tried spare key, that I know works, because I have started the car with it before - nothing.
    Scanned codes, ews module say's everything is ok. Bmw scanner even shows green next to the starter activisaton ( or something along those lines ). Have not got the chance to be under the car with a multi meter, when the problem occurs. Could it be a ignition switch issue?
    Best wishes, Reinis
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Im betting the starter is bad. Good on you performing the proper diagnostic tests.
    Jan 2013
    Latvia
    E36 Touring
    Got the ignition switch out today. Disassembled it and the contacts that switch 12v to the ews, while holding the key to crank, were really dirty, almost burnt looking. Cleaned them with sandpaper. Cranks, starts as it should for now. Hope the problem is fixed, but only morning will tell.
    Jan 2013
    Latvia
    E36 Touring
    Update!
    Morning came ad still - no crank!!!
    Hate intermittent problems.
    Hope it still does not start, when I get home, so I can start checking other things.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think the solution is to replace the ignition switch.
  1. Replies: 10
    Last Post: 10-16-2008, 04:01 PM
  2. 98 528i not cranking after battery light comes on
    By racermp in forum 1996 - 2003 (E39)
    Last Post: 05-31-2007, 08:52 AM
  3. E36 will not crank
    By Conclusive in forum 1991 - 1999 (E36)
    Last Post: 05-03-2007, 10:44 AM
  4. S52 underdrive pulleys (not crank) VPD...
    By s52e368 in forum BMW Parts For Sale
    Last Post: 04-20-2006, 08:14 AM
  5. Help - Car just studders and does not crank..
    By gota525i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-02-2006, 05:04 PM
