So I replaced my OEM nav system, radio, DSP amp, CD player with an all pioneer system , speakers ,amp, subwoofer, etc. and I knew I would lose the ability to change the functions in my cluster display so I was thinking maybe I could wire one of these up put it in the glovebox or just have the ability to plug or unplug it while I change the date, time or some other cluster function I have lost . I really don't need those functions as the Pioneer system has that but I just got a new battery and every time I start the car now it chimes to tell me the milage in the gas tank, kind of annoying. When I looked at a diagram of the Ibus system it seems that all those functions only need a monitor to change since its all controlled at the button on the turn signal
Hope this works cause I’m in the same dilemma.
Easy deal, you just take your dsp unit and power it anywhere then connect the bus wire to it. I think its blue with a white stripe. The way these wires are coded you can patch into them anywhere and get the same result.
I controlled ibus from a patch next to the amp.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
You are all talking about different things. The picture OP posted, is of the DSP screen. OP you need the MID in order to change the OBC functions (that's the wide rectangular piece). The thing in your picture only lets you adjust the DSP settings.
No it's not easy, as you don't have the MID wiring harness there a non-nav car would have. You may be able to fab up a harness that supplies the wires necessary. Not only that, nav cars are coded such, and MID cars are coded as such. Not sure if things will work properly without the coding.
I have the oem radio head unit in the trunk powered up and tapped into the bus. It talks to it fine. Should be the same for the mid and dsp box. Plenty of cars in the yard with that connector. The only thing you need to do is send the tiny packet to the bus, I found something cool looking around for some real bus fun!
https://www.instructables.com/id/Yes...in-30-Seconds/
Z1XX Upholstery
As Schl.Nr. B9EG.
Schl.Nr. P5EG
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
