So I was looking at my spare V8 and I noticed the ASC horn has a ton of casting marks on the inside and that the throttle body has a ridge. I think I want to try a port and polish on these guys and see how much of a throttle difference it makes on them. Polish the outside of them too for aesthetic reasons of course. Any input?
I noticed the heads have casting marks in the runners too. Anyone try a port on them? Id be interested to pull the heads on my second engine and port them.
New Daily:
2011 Audi A6 Avant 3.0T prestige. 1 of 368
----FOR SALE-----
04 BMW 325xi 143k
The Fun car:
94' BMW 740i 308k miles
Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
Sold:
1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
After squeezing ever last drop out of that engine by other methods this work might net you enough extra power to be measured several places to the right of a decimal point.
That minimally? I figured it would've been at least like a couple horse with how course the surfaces are. Oh well I suppose.
New Daily:
----FOR SALE-----
04 BMW 325xi 143k
The Fun car:
Sold:
Tell me if these e38 heater valves ???
Me E30 87/ 325i + F25 12/ M-Sport + E32 94/ 740i
G/F’s E34 92/ 525iT + F48 18/ X1
I was at the junkyard to pickup the heater valves from an E38 since I noticed the seals were the same so I decided to pull it apart to get new needles from it and found they don't separate from the ballast up in the coil. I then noticed the plate construction between the two was nearly exactly the same as the E32 except the E38 had dowels in it. I drilled the dowels out and filed it down then everything bolted back together and was hunky dory.
Another option I have seen done is people will swap the entire valve assembly and just swap over the connector. Personally I like to stick to OEM+ so I did it my way. One of my other projects is incorporating ambient lighting into the E32 but im probably going to reverse that.
New Daily:
----FOR SALE-----
04 BMW 325xi 143k
The Fun car:
Sold:
That’s awesome ! I have an extra e38 valve and bad e34... i might give it a try !
