Results 1 to 12 of 12
Thread: Swapping instrument cluster, question
    Wisconsin
    1995 BMW M3
    I have a 2002 325 i that the pixels are shot on my cluster. I can 't even read the mileage, lol. I got a used cluster but when I installed it, the dsc light and brake light is on. I really don't care about the red dot, but the other two bug me. Any feedback? I know, I should get a new one and have the dealer program it, but I am not spending that kind of money on this old car. Any advice? Thx.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Is the part number of each cluster the same as the other cluster? It seems BMW changed the design of the E46 cluster several times during the chassis’s production.
    Jan 2017
    USA
    E21, E46
    Agreed make sure they are truly the same as you should only have a tamper dot lit on the display.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    And the tamper dot can be gotten rid of via proper programming the cluster so it matches the miles data stored in the lighting control module (LKM).
    Wisconsin
    1995 BMW M3
    The light control module has been changed in the past, so I really don't care about the tamper dot. I am concerned about the yellow traction control light and the red brake light. Any way to get these off? Here are the numbers on the back of the clusters. Which numbers need to match in order for it to work?
    Jan 2017
    USA
    E21, E46
    The part numbers are different. Replace the cluster with the same part number.
    Wisconsin
    1995 BMW M3
    which number is the part number?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    11-11-1-111-111 is an example of a BMW part #. I think the part # (it should have the same format as the example) of the original cluster needs to match the part # of the replacement cluster.
    Jul 2004
    Houston, TX
    36 Cylinders
    The DSC checks against the VIN in the cluster. If it's mismatched to DSC, it will trigger those lights.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Wisconsin
    1995 BMW M3
    Even if the new cluster is the same part number?
    Jul 2004
    Houston, TX
    36 Cylinders
    In this case, it's all about the VIN; the ABS/DSC communicates to the cluster. If you have any way to read the errors in DSC and cluster, you will see.
    -Abel
    Jan 2017
    USA
    E21, E46
    Just to make sure you are not getting confusing data....
    If you get a same part number cluster you will only see the tamper dot. You can code that out if you research it.
    The other lights in your case are due to mismatched cluster.
    Ask me how I know. I have swapped clusters on many BMWs while troubleshooting or resolving for example: can bus issues due to a malfunctioning cluster.
  1. instrument cluster questions....
    By NoSoup4U in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-12-2011, 12:23 PM
  2. e34 auto to manual swap instrument cluster question...
    By andrewcconti in forum 1988 - 1996 (E34)
    Last Post: 04-12-2008, 05:02 PM
  3. Instrument cluster question
    By DominikM3 in forum 1983 - 1991 (E30)
    Last Post: 03-10-2005, 04:08 PM
  4. Instrument cluster questions
    By e36driver in forum 1991 - 1999 (E36)
    Last Post: 06-14-2003, 06:52 AM
  5. INstrument Cluster Question
    By mrdoenutz in forum 1991 - 1999 (E36)
    Last Post: 09-24-2001, 09:56 AM
