Out of nowhere, while driving today ...after a few days of sitting, at about 30-35mph, my steering wheel began to shudder. I turned around and headed home. It continued shake intermittently on the 2 mile return trip. When I got home I thought I could smell clutch.
Could low transmission fluid cause this to happen? I had my tranny drained and fluid replaced about a year and a half ago - with some that Dr Tranny Shudder Fix added.
It almost felt like a wheel was loose or had mud in it. But I don’t think that’s the issue.
Any thoughts are appreciated.
Jay
'01 325Ci Convertible, 5-speed
'01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
'03 X5 3.0 six cyl, Gray on gray
No. They are separate systems.
Did you check your steering fluid? (which is ATF, also) Its beside your oil filter.
Alternatively there could be a loose bolt on the pump, a weak tensioner etc.
2001 | DINAN 7 Sport | S62 Swapped 6-Speed
DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
Dual Pane Glass | Black & Sand Int.
2001 | 750iL | AlpineWeiss III
@scotthduke on Instagram
The smell of a clutch burning is very similar to brakes cooking - and that is your most likely cause of the shake, a brake caliper seized....
My BMW Repair YouTube Channel
Thank you both, I'll go investigate each.
It is also worth saying to check the tyre pressures - low pressure also causes shake at low speed....
The simple answer is no they are unrelated, but if your transmission is shuddering, I could maybe see it shaking the wheel IF it is shuddering violently enough. But you'd feel it in the seat and the rest of the car. The previous suggestions are spot on.
probably the control arm bushings are shot
2001 740i M-Sport
All Stock, 142K miles
Interesting that, after a 5 mile test drive, there was no shudder. It was a bit warmer today. After the drive, when I did open both driver and passenger front windows and I thought I could hear a little brake/rotor rubbing. Verrrry little. Not rhythmic, which would support a warped rotor. AND, when I got home, none of the 4 wheels were even warm. Wondering if one of the calipers did stay on and was grabbing the rotor, but, today - with a bit warmer out, the caliper relaxed enough to not be an issue. As soon as this shudder returns, I'll check which wheel is warm and likely replace that caliper. (I do wonder, if I take the caliper/yoke apart and clean where both parts slide on one another... maybe that helps/resolves the issue).
Thanks all,
Jay
