Results 1 to 10 of 10
Thread: Can low tranny fluid make steering wheel shake?
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Out of nowhere, while driving today ...after a few days of sitting, at about 30-35mph, my steering wheel began to shudder. I turned around and headed home. It continued shake intermittently on the 2 mile return trip. When I got home I thought I could smell clutch.
    Could low transmission fluid cause this to happen? I had my tranny drained and fluid replaced about a year and a half ago - with some that Dr Tranny Shudder Fix added.
    It almost felt like a wheel was loose or had mud in it. But I don’t think that’s the issue.
    Any thoughts are appreciated.
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    No. They are separate systems.
    Did you check your steering fluid? (which is ATF, also) Its beside your oil filter.
    Alternatively there could be a loose bolt on the pump, a weak tensioner etc.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The smell of a clutch burning is very similar to brakes cooking - and that is your most likely cause of the shake, a brake caliper seized....
    My BMW Repair YouTube Channel
    Oct 2007
    Bolton, MA
    Thank you both, I'll go investigate each.
    May 2013
    Rochester, NY
    2001 740i Sport
    Quote Originally Posted by Timm View Post
    To add to this, if you have an IR (non-contact) thermometer, take the car for a drive, then park it and immediately check the temperature of the brakes on each corner. If one corner stands out as extra warm, that's the one with the problem.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It is also worth saying to check the tyre pressures - low pressure also causes shake at low speed....
    Oct 2007
    Bolton, MA
    Quote Originally Posted by rslifkin View Post
    Thank you. Yes, I have an IR thermometer - it's my hand. I have done this before, drive around a bit and then slowly move my hand to the wheel to see if it's cool/slightly warm or hot as a bastid! I will safely check.
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    The simple answer is no they are unrelated, but if your transmission is shuddering, I could maybe see it shaking the wheel IF it is shuddering violently enough. But you'd feel it in the seat and the rest of the car. The previous suggestions are spot on.
    '98 740il | 9/97 build | schwarz 2 | sandbeige | 5AT | 270k
    '04 330i ZHP sedan | Mystic blue | Alcantara | 6MT | 120k
    '00 540i sport | Titanium silver | Black | 5AT | 152k
    '85 Mustang GT convertible | Medium charcoal metallic | Gray | 5MT | 216k | one owner, all original
    mods: m-pars | Bilsteins & B&G springs | ValentineOne | StealthOne
    retrofits: full nav | MKIV | bluetooth TCU | BM53 w/ AUX input | video module w/ AV input & backup cam | oem sirius xm | xenon | shades | PDC | rain sensor | BMW DWS TPMS | lighted door handles | front seat heaters | heated steering wheel | euro rear fog lights | ski pass | folding mirrors
    May 2018
    Omaha Nebraska
    2001 740i M Sport
    probably the control arm bushings are shot
    2001 740i M-Sport
    All Stock, 142K miles
    Oct 2007
    Bolton, MA
    Interesting that, after a 5 mile test drive, there was no shudder. It was a bit warmer today. After the drive, when I did open both driver and passenger front windows and I thought I could hear a little brake/rotor rubbing. Verrrry little. Not rhythmic, which would support a warped rotor. AND, when I got home, none of the 4 wheels were even warm. Wondering if one of the calipers did stay on and was grabbing the rotor, but, today - with a bit warmer out, the caliper relaxed enough to not be an issue. As soon as this shudder returns, I'll check which wheel is warm and likely replace that caliper. (I do wonder, if I take the caliper/yoke apart and clean where both parts slide on one another... maybe that helps/resolves the issue).
    Thanks all,
    Jay
  1. Car steering Wheel Shaking and turning over bumps at low Speeds
    By ezx248 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-30-2011, 12:40 AM
  2. Steering Wheel Shake
    By TheBestCow in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-25-2002, 08:26 PM
  3. Steering wheel shaking during braking???
    By moonluv810 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-03-2002, 09:12 AM
  4. My steering wheel shakes?
    By wicked in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-20-2002, 04:55 PM
  5. Replies: 5
    Last Post: 08-30-2001, 07:29 PM
